I have 232 roms for Winkawaks, but when I go to my Winkawaks menu in GameEx it shows 248roms and there are a few games that are appearing at the top of my list, followed by a blank space and then the full list of roms. I'm not sure how these games are showing up there, but I can't seem to remove them. I'm not sure what I did, but every time I try do a reinstall Winkawaks and add the roms some games are going to the top. Any help to fix this is appreciated.
Hi! The games you are seeing at the top of your list are "Last/Most Played". To switch it off go to Advanced Emulator Setup using the setup wizard and change to:
Show last played = No
Alternatively manually edit your GameEx.ini and File>Save.
