I know this is geared toward the VP forum, but I see a lot of posts about using the mapping key function of GameEx. I've never used that function so if it's an option a little tutorial on doing the first key combo would help.
I currently have the plunger set to 'F' (Right joy down) on my x-arcade. The problem is when some people play, they snap the joystick down which in turn makes it hit 'R' (Right joy up) at times.
It looks like the 'R' key is optional and NOT handled in the VPMkeys.vbs file, nor can it be changed in the VP. What are my options?
Map R to Left Shift and W to R via AutoHotkey?
I would rather stay away from changing modes on the xarcade since I will be dropping it into a cabinet.
Z
Aren´t the rules a Frontend (e.g. hyperpin) thing? I dont use Hyperpin and the R key does exactly nothing in VP
