hi, im trying to get my sega cd games to show up in gameex, but only the bin/cue ones are showing up. none of my iso's are... ive added *.bin; *.cue; *.iso to the roms filter, but im still not getting any sega cd isos... any ideas?
also, some of the games are in a format where there's one .iso and several mp3s. dumping all of that stuff into one folder is kinda a mess... can i use isobuster or something to convert these to bin/cue files, or just take all the games and unpack them (again, with isobuster) into individual folders and set "roms in folders" to true?
ive got about 30gb of sega cd games, so im hesitant to go ahead with these ideas until i get a second opinion! :lol:
Im pretty sure GameEx dosent support sub foldering "yet" so you have to put all iso,cue ect ect in the same folder to show up ..
I agree with you if you have the iso/mp3 rips of the sega CD`s its a mess but you can merge them again (but they will take up more space on your HD) and i doubt iso buster can do the trick tho ...
Night
if the iso's still don't show once all the files are in the same folder, try adding a semicolen to the end of your filter config text:
*.bin;*.cue;*.iso;
you could also try to move the "*.iso;" to the first slot to check if it works there rather than at the end.
don't know if that'll help or not but thought i'd post anyhow.
