Hello!
After searching a long time how to match the real rendering of an Amiga with WinUAE on my cab,and not findind on the web the way to do it, i can say i've finally found after hours of tests the perfect settings (at least for me). Here we are :
First, you have to set your resolution to 640x576 (you can add this one to your resolutions with Winmodeline, see attachment)
Then, in the "display" tab of WinUAE, set :
Screen : 640x576 - Default resfresh Rate - Triple Buffering
Settings : Fullscreen - Legacy
Resolution : Hires(normal)
Centering : Horizontal &Vertical ticked
LineMode : Scanlines
Then in the "Filter" tab, set :
Filter settings ; none
That's all
And you have a perfect scanlined display as it was rendered on original amiga monitor without tearing and the screen is not shrinked or scaled
For the CD32, keep the same settings but set the resolution to 720x576 instead of 640x576
Let me know what you think about those settings!!
WinModelines.zip
