I got a bit of a wierd error. Say...I load up GameEx and launch a MAME game, I then return to the menu after the game. Sometimes the jukebox replays the same song twice, but when I go to the jukebox to change songs, I select a song and I hear the little selection beep, but the song doesn't change. What do you think this is? Is there anyway to fix it? Thanks a bunch!
Are you sure this is not just by design??
After exiting a game, GameEx 'resumes' the sone that was playing.
It also loops the songs in the queue when it reaches the end. So if only one song has been selected it will keep repeating.
The Jukebox 'queues' songs. Think of it like a physical jukebox. The first song you select is the first in te queue, any songs selected after that are added to the queue and will play next or later.
Check out the keys to skip through the playlist, or use the mouse.
Oh, I see what you mean, I was looking at it as more of a media player than a jukebox. Thanks Tom, sorry for the dumb question.
