[resolved] Re-mapping L key for control panel viewer not working
Hey guys, tried to search the forums etc but everything suggested has not worked for me.
I'm trying to disable the L key (or re-map it).
I have the control panel viewer options turned off and removed the paths in the gameex ini file.
what am I missing?
Also searched all ini files for mention of the vcode or scancodes for L and no luck.
basically want the control panel viewer option off.
cheers
V
Hi Venomouse
Sounds like you've done your homework, but all the same, it would be helpful to have a look at your GameEx config and log file so we're looking at the same thing you are. In terms of the log it might be helpful to recreate the issue and post your log immediately after closing GameEx. Also just to save an extra step, please make sure you're running the most recent version of GameEx (there have been a few updates this week). Thanks!
Awesome Venomouse! I'm glad to hear you got everything sorted out.
Edited by nullPointer
