Key mappings n' Stuff.
Guest Archived From Old Forum
Glad you like the Jukebox, I'll see what I can do maybe.
1) Not sure I can do a lot about that. I must say I did notice that as well. I've got one thing to try though.
I think the problem is that Project 64 is catching the escape key before GameEx. It does take a while to exit back to GameEx sometimes, so you may not actually need to hit escape twice. Normally the Escape key in project 64 switches from full screen.
2) Ive added the info about IPAC requiring the SlikStick setting to the docs page and gameex.ini.
I would rather just add on payer 2 joystick paging the ist, then having redefinabe keys. I want to try and keep gameex simple, and easy to setup and use for all people, and I don't feel redefinable keys complies with that.
Yes, do please post your configs.
Thanks.
Since I last posted, and questioned you about the inclusion of the
jukebox in Gameex, let me just say how wrong I was..... ;)
Over the weekend I installed the lastest version (of which there is
all ready a newer version, Man your quick!) and had my first taste
of the Jukebox, which I quickly fell in love with.
Question, is it possible to display the current track and playlist
inside Gameex? and, can the jukebox be made to keep running in the
background while a game is in progress? (I loved it so much, I
missed it when I started a game and it shutdown.....)
Heres just a couple others I ran into:
1) Project 64, theres some error "beep" when exiting back gameex
that hangs the exit, P64 exits, and is no longer running, but gameex
doesn't come back until ESC is pressed again. I'm going to try it
again tonight without hideos to see if I can see what it is. Also,
is there some way, to display the compatibility info, or to add the
ability to block the listing of the issued roms in the EMU? (I don't
know if its possible to do the verify as in mame.)
2) Keyboard mappings. like the other posts, I had a couple issues on
my cab with the buttons, until I ran across the Slikstik setting. I
threw me at first since I'm running a Ipac, until I read on your
docs page about it. Maybe clarify the .ini as to its for all
encoders? And I'm sort of in the same mindset as others, it would be
nice to have a configurable keymap, possibly a different ini file?
Eg, I would love it if R & F were pageup and pagedwn, as that's the
default player 2 joystick up and down.
Other than that, no issues here, a few hours writing all the configs
for all the rest of the Daphne roms and enhancements and cab wiring
changes kept me busy the weekend but so far so good!
Thanks again for such a nice FE, I'm going to try and get some time
this week to write up configs for the rest of my Emu's and post them.
Sound Doc
