  On 10/17/2012 at 12:03 PM, Draco1962 said:
This link will give you the instructions you need to post your emulator config via Setup Wizard. Whenever dealing with issues for a specific emulator problem, it is best to provide the emulator config from GameEx in addition to the gameex.ini and log.txt file generated after the issue occurs when attempting to play a game from within that emulator. Thanks!
cool! I will as soon as I get home :)
I would personally not use zsnes as this does suffer some tiling issues.
I was actiay going through the snes emus last night and it really is a toss up between snes9x and snesgt.
Personally snesgt wins for me (remember to tick the CPU sleep). It may not be the most accurate, but I want 60fps.
  On 10/17/2012 at 2:22 AM, fRequEnCy said:
Please export your config so that I can see what settings you have so that I can figure out a way to tweak to get it to work. It's easily done in command-line. Now we just need to translate it to do as you mentioned (read the folders instead of roms).
here is my ini, my log and the emulator settings.
as it is right now, I can run and play games, but that's because I used my workaround (copied all the SFC files to the ROM folder, scanned them with gameex, exit gameex, and replace the sfc with the folders for bsnes)
if you can find a way to make GameEx consider the folders as actual Roms we will be golden :D
btw, don't mind that the emulator settings say its for version 88, as I just replaced the files in the folder :)
gameex.ini
Console Nintendo SNES (BSNES).ini
first time I hear about SnetGT, going to try it :) thanks!
When you're available then meet me in the chat room. That why we can troubleshoot in real-time instead of sending messages back and forth. I'll be around for awhile.
I just thought I would post my SnesGT config (for the emu, not GameEx) as this gives me a wonderful super slick 60fps (by running at 59 in update - though for crt, you would perhaps have to set to 60).
Well, you may wanna give it a whirl.
SNESGT.rar
Thanks, I've been trying SnesGT, and I am in love! :P forget Bsnes! :D
Thank you fRequEnCy for your help :) I have now upgraded to a lifetime registration, your help and the awesome help I received in this board, and not to mention the awesomeness that is GameEX made me decide for it :D
  • 2 months later...
If you still want to use bsnes
Download bsnes 0.73 (with the old GUI)
With it, use "purify.exe" to convert your rom to .sfc format
Then download bsnes 0.88 and you can use your converted roms with it. And roms will be recognized by Gameex
Don't use latest bsnes 0.91 because it use a different rom management and it's not compatible with a front-end like gameex
I've done this method and i'm using bsnes with Gamex and it work great
If you want bsnes start fullscreen at start, don't forget to modify the file settings.cfg wich is in \users\Appdata\bnes\ and set Video::StartFullScreen to TRUE
I've set desktop to switch to 256x240 before launching bsnes, then i have perfect render of SNES Games (for me better than snes9x and znes, but it's only my opinion )
