Hello! :)
It's been awhile since I've been here (Work has been draining all my freetime lately....sooo can't wait until January :) )
Anyway, I started working on my cab again today - I finally got the Dragon's Lair DVD Video and have DaphneLoader application set up. But for some reason, I'm having a little difficulity in getting the game to start through GameEx. Everything runs fine in DaphneLoader, but when attempting to start the game through GameEx, the screen goes black, I hear a windows error sound, and all the buttons I press will make a "ding" sound.
Has anyone had this problem before, and if so, how do I fix it? :)
Thanks in advance!! :)
LC
Additional Information: I tried using both Daphne.exe and DaphneLoader.exe in the Setup Wizard, and both does the same result
GameEx.ini
Finally found out I did wrong! :)
I found a set of instructions on the net from a fellow gameex user. It was origionally a .pdf file, but I will post what the instructions said below.
Big thanks to JUSTINCASE!!!
"For those of you who are running the Daphne 1.0 beta and
have the 20th Anniversary DVD set (or other Digital Leisure
DVD's) This is how you set it up to work with Gameex.
1. Start DaphneLoader
2. Highlight Dragon's Lair
3. Hit the configure button
4. Choose the Advanced tab
5. Next to Display Command Line choose Enable
6. Hit Apply then OK
7. Now hit the start button and a command line box will pop up
8. Copy what is in the box
9. Now exit Daphne
10. Make sure that you also Exit DaphneLoader from the
bottom right of your screen by the computer clock
11. If you do not exit the DaphneLoader it WILL NOT RUN
USING GAMEEX
12. Open Gameex Configuration Menu
13. Choose Daphne
14. Under Game 1 Rom type in dle21 which I believe plays all
new scenes
15. Under Game 1 Options paste what you copied from the
Command Line Box
16. Make sure Game 1 ROM is Enabled
Please note: This guide assumes you have the daphne.exe setup
in the path according to your filestructure..
Enjoy!
The credit for this instruction sheet belongs to JUSTINCASE."
Awesome! I'm glad you found the answer you were looking for thurmansevolution!
Edited by nullPointer
