I keep getting the following errors after trying to exit a specific emulator menu.
10:16:04.7 2/20/2006: 21 Consecutive Exceptions Occured: Exiting
10:16:04.7 2/20/2006: Cannot access a disposed object named "Microsoft.DirectX.DirectDraw.Surface".
Object name: "Microsoft.DirectX.DirectDraw.Surface".
10:16:04.7 2/20/2006: at Microsoft.DirectX.DirectDraw.Surface.get_SurfaceDescription()
10:16:04.7 2/20/2006: at GameEx.GameEx.mainform.DisplayFrame()
Also, my nonmane games (which are zipped) are not showing up at all for selection regardless if a filter is used. Does anybody have any suggestions? Any help would be appreciated. Thanks
-Berg
-Berg
Could you post your full log, along with your config file. please.
Could you also detail exactly when the above erros happend.
I decided to uninstall and start over b/c I was having other problems as well. I'll post the new "troubles" as they come. Thanks
