Here's what I get when trying to lunch gameex:
18:48:33.3 17/02/2006: Operating System Platform: Win32NT
18:48:33.3 17/02/2006: Operating System Name: Windows XP
18:48:33.3 17/02/2006: Operating System Version: 5.1.2600
18:48:33.3 17/02/2006: Checking for versions of .net Framework installed
18:48:33.3 17/02/2006: .net Framework 1.0 Installed
18:48:33.3 17/02/2006: .net Framework 1.1 Installed
18:48:33.3 17/02/2006: .net Framework 2.0 Installed
18:48:33.3 17/02/2006: Checking Registration
18:48:33.3 17/02/2006: Running Randomize()
18:48:33.3 17/02/2006: Initialising Video/MNG DLL's
18:48:33.3 17/02/2006: Running Misc startup tasks
18:48:33.3 17/02/2006: Setting Menu types
18:48:33.3 17/02/2006: Opening Configuration File
18:48:33.3 17/02/2006: Getting Configuration Values
18:48:33.3 17/02/2006: Using Theme: Default - Default
18:48:33.3 17/02/2006: Checking for alternate Image Directory for Theme: Default - Default
18:48:33.3 17/02/2006: Text/Language: English
18:48:33.4 17/02/2006: Applying Language/Text
18:48:33.4 17/02/2006: Creating Scancodes.txt (List of DirectInput scan codes)
18:48:33.4 17/02/2006: Snap Delay set to: 1
18:48:33.4 17/02/2006: Is Media Center running?
18:48:33.4 17/02/2006: Check Media Center Exit/Start Mode
18:48:33.4 17/02/2006: Media Center Mode 2
18:48:33.4 17/02/2006: Checking for applications to Launch On Startup
18:48:33.4 17/02/2006: Get other settings
18:48:33.4 17/02/2006: Using 2D Animations
18:48:33.5 17/02/2006: Set: Find emulator artwork on best match basis
18:48:33.5 17/02/2006: Launching HideOS.exe
18:48:34.4 17/02/2006: Hiding Taskbar
18:48:34.4 17/02/2006: Start work for Form
18:48:34.4 17/02/2006: Getting Original Screen Size
18:48:34.4 17/02/2006: Loading ICON
18:48:34.5 17/02/2006: Initializing Component
18:48:34.5 17/02/2006: Initialising Bass Audio Library
18:48:34.7 17/02/2006: Loading default loading screen
18:48:34.7 17/02/2006: Using General Font: Trebuchet MS
18:48:34.7 17/02/2006: Using Title Font: Trebuchet MS
18:48:34.7 17/02/2006: Initialising DirectDraw
18:48:34.8 17/02/2006: Creating DirectDraw Device
18:48:34.8 17/02/2006: Using Device: RADEON 9800 SERIES
18:48:34.9 17/02/2006: Setting Resolution to 800x600 32 bit color
18:48:36.0 17/02/2006: Creating DirectDraw Surfaces
18:48:36.0 17/02/2006: Creating Primary Surface - Full Screen Mode
18:48:36.0 17/02/2006: Creating Back Buffer
18:48:36.1 17/02/2006: Loading graphic surfaces
18:48:36.1 17/02/2006: Creating Surfaces Misc and Dialogs
18:48:36.1 17/02/2006: Creating Surface Volume
18:48:36.2 17/02/2006: Creating Surfaces Arrows
18:48:36.2 17/02/2006: Creating Surfaces GameEXlogo Text
18:48:36.2 17/02/2006: Creating Surfaces Toolbar
18:48:36.2 17/02/2006: Creating Surfaces Backgrounds
18:48:36.9 17/02/2006: Creating Surfaces Toolbar Controls
18:48:36.9 17/02/2006: Creating Surfaces GameEx Logo
18:48:36.9 17/02/2006: Creating Surfaces Home & Exit
18:48:37.0 17/02/2006: Creating Surfaces Snaps
18:48:37.0 17/02/2006: Creating Surfaces Menu and List Bars
18:48:37.1 17/02/2006: Creating Fonts
18:48:37.1 17/02/2006: Creating Menu Font
18:48:37.2 17/02/2006: Creating Game Font
18:48:37.2 17/02/2006: Creating Game Font Standard Size
18:48:37.7 17/02/2006: Creating Font Black
18:48:37.8 17/02/2006: Creating Font Black Small
18:48:37.8 17/02/2006: Creating Game Font Faded
18:48:37.9 17/02/2006: Creating Title Font
18:48:38.0 17/02/2006: Creating Control Panel Font
18:48:38.5 17/02/2006: Fonts Created Succesfully
18:49:00.5 17/02/2006: Initialising Windows Media Player Component
18:49:00.6 17/02/2006: MAME Path is: D:\mame\Mame32
18:49:00.6 17/02/2006: MAME EXE file is: mame32fxpp.exe
18:49:00.6 17/02/2006: Cannot Find Mame.exe
18:49:04.3 17/02/2006: ERRORS DETECTED: EXITING
How do I fixe this!!
Protecteur
I'm no expert but it looks like you are using a custom mame build and you don't have the path set to the exe correctly.Does it exit on startup of gameex or on launching a game because I believe the newer versions of gameex will still launch into the gameex menu even if no mame exe is present.
