Hola gents - Tom - you and your FE rule beyond possible description.
SO - I recall running across an item on this forum which I cannot for the life of my find now(much like my car keys and willpower in regards to beer).
I don't want to go buggering with the horizontal coil on my arcade monitor - and my Ultimarc Avga card doesn't seem to have a screen adjustment built-in. (or at least I can't find it, which is not a shock really.)
Someone once posted an appy that allows you to adjust your screen size? I've tried the GameEx screen settings, but once I go over a certain number the FE won't boot and I get an error log.
Would love to get my hands on that app. And a Nutting Associate's Computer Space. Yah - one out of two won't be bad.
Thanks gents!
James
Thanks gents!
James
I think your looking for Powerstrip:
http://entechtaiwan.net/util/ps.shtm
However I recommend strongly you dont use it with an ArcadeVGA. I'm afraid you should bugger with your Arcade monitor instead, and this aint the best forum to get help with that.
