I'm having a little problem when I quit emulators and return to GameEX. I hit esc to quit the emulator, emulator quits and it goes to desktop for five seconds, and then GameEX starts up again, but the screen is completely messed up. Then a little later GameEX quits to the logfile and I get the "20 exceptions in a row" error. Anyone else had the same problems?
I continue to get random "20 consecutive exceptions in a row" error messages but I don't see a messed up GameEX screen prior to the crash. My error messages occur without warning and I have yet to determine exactly what causes it. It's just a nuisance I've learned to live with at this point. Your problem sound much worse though. It's got me stumped!
Jeff
Oh, it's not that big of a deal. When it quits out I can get back to Sage with just my remote so I don't even need to get off the couch to fix things. I'm playing around with my settings to see if I can't just change some graphical options in GameEX or my emulators to fix things. I'll post if I figure something out.
Jeff
Evilpenguin,
No idea sorry. Your message seems to hint this is with lots of emulators. Are you sure its not with one (or two) in particular?
Jeff, oh well I thought we conquered that one.
Did you try the sleep setting as I suggested?
Yeah, it's pretty much every emulator. VirtualNES, VirtualBoy Advance, and Gens all do the same thing. I've only tried running them in fullscreen up until now. Tommorow i'll mess with the emulator configs what I can find.
Evilpenguin,
I've played with various sleep settings and have not found anything that's worked yet. Right now I have it set for 3 MS and it hasn't crashed in a few days. I'll let you know if it happens again.
Do you think this might be something to do with the way you are launching GameEx from Sage perhaps?
Right on the money. I don't think GameEX likes that Sage is running in fullscreen mode behind it. I should be able to handle this from the Sage side, maybe minimize on launch or something.
Ok, I tried a few things.
1- I tried leaving sage in fullscreen mode and making a call to show desktop before I launched GameEX and the problem remained.
2- I set sage to minimize to taskbar on sleep and apparently it liked that.
I can live with solution two, except I would really like a clean way to relaunch sage after GameEX exits. Is there anyway to get GameEX to run a generic cmd command when it shuts down? That way I could set up a batch file to wake Sage up when GameEX quits.
There is another way to do this, and that is create a batch file to launch gameex and then on exit launch Sage. Something like this.
Create c:\runit.bat
C:
CD "\Program files\GameEx"
GameEx.exe
C:
CD "\Program files\Sage"
sage.exe
Tell sage to launch this batch file instead of GameEx.exe
You might need to play around a little.
Hi Tom,
I'm building a MAME system and would like to use your GAMEEX front end tool because of its beautiful display. For the most part, everything running great. However, I'm getting the same error message and crash as evilpenquin. I don't run any SAGE program at all. Just straight from window XP. I'm trying to launch both MAME and GAMEEX with 1024x768 settings.
The crashes happened quite often and it has becoming kinda annoying when I was trying to show off the system to my cousins/friends this past weekend (just had it working last week). Happen about 3rd or 4th time I launch or quit any game with ESC key.
Please help me out. Sorry I have to email you since I can't seem to post/reply to any message even though I've created an account "hieule91" and logged it.
Thx
Hieu
Here is the log file:
23:36:34.8 3/27/2005: GameEx: Version 3.45: Starting Log
23:36:34.9 3/27/2005: Operating System Platform ID: Win32NT
23:36:34.9 3/27/2005: Operating System Version: 5.1
23:36:34.9 3/27/2005: Running Randomize()
23:36:34.9 3/27/2005: Running Misc startup tasks
23:36:34.9 3/27/2005: Hiding Cursor
23:36:34.9 3/27/2005: Opening Configuration File
23:36:34.9 3/27/2005: Getting Configuration Values
23:36:34.9 3/27/2005: Using Theme: Default - Video Fun
23:36:34.9 3/27/2005: Checking for alternate Image Directory for Theme: Default - Video Fun
23:36:34.9 3/27/2005: Applying Language/Text
23:36:34.9 3/27/2005: Launching HideOS.exe
23:36:35.6 3/27/2005: Hiding Taskbar
23:36:35.7 3/27/2005: Getting Original Screen Size
23:36:35.7 3/27/2005: Loading ICON
23:36:35.7 3/27/2005: Initializing Component
23:36:35.7 3/27/2005: Using General Font: Trebuchet MS
23:36:35.7 3/27/2005: Using Title Font: Trebuchet MS
23:36:35.7 3/27/2005: Initialising DirectDraw
23:36:35.7 3/27/2005: Applying GameEx is Loading Image
23:36:35.8 3/27/2005: Creating DirectDraw Device
23:36:35.8 3/27/2005: Setting Resolution to 1024x768 32 bit color
23:36:37.0 3/27/2005: Creating DirectDraw Surfaces
23:36:37.0 3/27/2005: Creating Primary Surface - Full Screen Mode
23:36:37.1 3/27/2005: Creating Back Buffer
23:36:37.1 3/27/2005: Loading graphic surfaces
23:36:39.0 3/27/2005: Creating Fonts
23:36:39.0 3/27/2005: Creating Menu Font
23:36:39.1 3/27/2005: Creating Game Font
23:36:39.2 3/27/2005: Creating Menu Font Standard Size
23:36:39.6 3/27/2005: Creating Font Black
23:36:39.7 3/27/2005: Creating Font Black Small
23:36:39.7 3/27/2005: Creating Game Font Faded
23:36:39.8 3/27/2005: Creating Title Font
23:36:40.1 3/27/2005: Initialising Windows Media Player Component
23:36:40.1 3/27/2005: HTML Apps is on, initialising Web Browser Component
23:36:40.2 3/27/2005: MAME Path is: C:\mame\mame094b
23:36:40.2 3/27/2005: daphne Path is: D:\Daphne
23:36:40.2 3/27/2005: daphne EXE file is: Daphne.exe
23:36:40.2 3/27/2005: Use daphne on. Daphne.exe will launch games
23:36:40.2 3/27/2005: MAME EXE file is: mame.exe
23:36:40.2 3/27/2005: ROM Paths are: D:\MAMEDATA\mame1\roms;D:\MAMEDATA\mame2\roms;D:\MAMEDATA\mame3\roms;D:\MAMEDATA\mame4\roms;D:\MAMEDATA\mame5\roms;D:\MAMEDATA\mame6\roms;D:\MAMEDATA\mame7\roms;D:\MAMEDATA\mame8\roms;D:\MAMEDATA\mame9\roms;D:\MAMEDATA\mame10\roms
23:36:40.2 3/27/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
23:36:40.2 3/27/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
23:36:40.2 3/27/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
23:36:40.2 3/27/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
23:36:40.2 3/27/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
23:36:40.2 3/27/2005: Loading Custom Emulators
23:36:40.3 3/27/2005: Snap Path is: C:\mame\mame094b\snap
23:36:40.3 3/27/2005: AVI Snap Path is: C:\mame\mame_videos_shrunk
23:36:40.3 3/27/2005: Flyer Path is: C:\mame\mame094b\flyers
23:36:40.3 3/27/2005: Cabinet Path is: C:\mame\mame094b\cabinets
23:36:40.3 3/27/2005: Title Path is: C:\mame\mame094b\titles
23:36:40.3 3/27/2005: Panel Path is: C:\mame\mame094b\cpanel
23:36:40.3 3/27/2005: Icon Path is: C:\mame\mame094b\icons
23:36:40.3 3/27/2005: Marquee Path is: C:\mame\mame094b\marquees
23:36:40.3 3/27/2005: Attempting to load game list
23:36:40.4 3/27/2005: Loading last used Game List
23:36:40.6 3/27/2005: Initialising Bass Audio Library
23:36:40.8 3/27/2005: Loading music from Windows Media Player
23:36:40.8 3/27/2005: Error accessing Windows Media Player, check you are running Version 9 or above
23:36:40.8 3/27/2005: Turning off Jukebox
23:36:40.8 3/27/2005: Creating DirectSound Device
23:36:40.8 3/27/2005: Trying: Primary Sound Driver
23:36:40.8 3/27/2005: Loading Sound Files
23:36:40.8 3/27/2005: DirectSound Device Created Successfully
23:36:40.8 3/27/2005: Creating ICONS
23:36:40.8 3/27/2005: Restoring Cached ICONS from File
23:36:41.3 3/27/2005: Initialising DirectInput for Gamepad support
23:36:41.3 3/27/2005: Playing Startup Video
23:36:42.8 3/27/2005: Playing intro sound file
23:36:42.8 3/27/2005: Initialization OK! Starting GameEx!
23:36:42.8 3/27/2005: Testing Main Loop Once: Processing Frame
23:36:42.8 3/27/2005: Testing Main Loop Once: Getting Tick count
23:36:42.8 3/27/2005: Testing Main Loop Once: Checking for song change
23:36:42.8 3/27/2005: Testing Main Loop Once: Front buffer exists?
23:36:42.8 3/27/2005: Testing Main Loop Once: Surfaces need restore?
23:36:42.8 3/27/2005: Testing Main Loop Once: Checking Joystick for input
23:36:42.8 3/27/2005: Testing Main Loop Once: Drawing Background
23:36:42.9 3/27/2005: Testing Main Loop Once: Drawing Logo
23:36:42.9 3/27/2005: Testing Main Loop Once: Flipping Surfaces
23:36:42.9 3/27/2005: Testing Main Loop Once: Main Loop ran successfully
23:37:09.9 3/27/2005: Running: cmd.exe /c C: C:\mame\mame094b\mame.exe mvsc -rompath D:\MAMEDATA\mame1\roms;D:\MAMEDATA\mame2\roms;D:\MAMEDATA\mame3\roms;D:\MAMEDATA\mame4\roms;D:\MAMEDATA\mame5\roms;D:\MAMEDATA\mame6\roms;D:\MAMEDATA\mame7\roms;D:\MAMEDATA\mame8\roms;D:\MAMEDATA\mame9\roms;D:\MAMEDATA\mame10\roms -skip_disclaimer -skip_gameinfo -resolution 1280x768x32 -triplebuffer -nouse_bezels -nowindow -joy
23:40:32.5 3/27/2005: Running: cmd.exe /c C: C:\mame\mame094b\mame.exe mshu -rompath D:\MAMEDATA\mame1\roms;D:\MAMEDATA\mame2\roms;D:\MAMEDATA\mame3\roms;D:\MAMEDATA\mame4\roms;D:\MAMEDATA\mame5\roms;D:\MAMEDATA\mame6\roms;D:\MAMEDATA\mame7\roms;D:\MAMEDATA\mame8\roms;D:\MAMEDATA\mame9\roms;D:\MAMEDATA\mame10\roms -skip_disclaimer -skip_gameinfo -resolution 1280x768x32 -triplebuffer -nouse_bezels -nowindow -joy
23:42:19.9 3/27/2005: 20 Consecutive Exceptions Occured: Exiting
Hi Tom,
Can you try using the latest version 3.47. If that does not work, just use the default theme and not the video one. I think it may be the newly implemented background video feature. Although it would be useful to me to know if I fixed this in version 3.47.
There is a link to 3.47 on the forum. It IS NOT a BETA version.
Please let us know your results.
Tom,
I tried it last night w/ version 3.47 and still got the same crash. I'll try again with the default theme
thx
Hieu
Hi Tom,
firstly thanks for such a great product, love the features.
I too am getting the same problem, I have the latest version 3.48 but as with the last two versions I still get the 20 consecutive expections error.
I am only running mame, and am using the default layout.
Regards Michael
Hi Tom,
Regards Michael
Michael and hieule91.
Can you please replace GameEx.exe with the one in the attachment. Then post the log. You may need to zip it as it will be big.
This is a debug version of 3.48 that will run slow, but should hopefully log enough info to tell me where its going wrong.
Thanks,
Tom
GameEx.zip
Thanks,
Tom
Tom,
here is a logfile with the crash, whilst this time the program crashed while I was viewing a cabinet picture, on previous occasions the crash has occurred straight after exiting a game.
Thanks,
Tom
Tom,
Thanks,
Tom
Tom,
