Is this problem back?
After booting my cabinet, attract mode loses focus the first time around. All that is visible is the Windows 7 taskbar.
Alt-tab to get back to GameEx is not ideal.
Regardless, many thanks for the updates!
- Ian
Your log doesn't show any kind of interaction with Attract Mode at all. :(
When a game lunches in Attract Mode on my machine it puts in an entry, like so:
22:05:53.7 8/31/2012: Running: cmd.exe /c F: F:\Emulators\MAME\mame.exe skyarmy -rompath F:\Emulators\MAME\roms -nowindow -joy -mt -video d3d -mouse -noka -volume -32 -bezel -artpath artworkgameex
Your log doesn't even have any evidence of it doing anything at all, so...
Ah, I have no idea why that happened as I did recreate the bug for that log.
I tried again, and this time there is more information in the log, here:
The conditions of this test are that GameEx is started automatically with windows and there is no input from user.
A moment ago I ran the test and Super Sprint started from attract mode - for 5 seconds, before minimizing. Then all I had was a hidden desktop with the windows 7 taskbar.
Thanks to Adultery and anyone considering this problem.
This log definitely shows what happened, but the reason why is not so readily apparent.
01:50:22.7 05/09/2012: Running: cmd.exe /c K: K:\Emulation\MAME\mame64.exe jumping -rompath K:\Emulation\MAME\roms -nowindow -joy -skip_gameinfo
01:50:45.1 05/09/2012: Key/Joy press detected: Exiting Attract mode, closing MAME
So GameEx is detecting some sort of input and exiting Attract Mode. I’ll attempt to duplicate this when I get home tonight. In the meantime, I don’t suppose you can see if the same thing happens on a different machine?
This may be a hardware issue?
Thanks for looking, let me run through what happens
I turn on the machine from cold and eventually:
1 minute passes
01:50:19.6 05/09/2012: Starting Attract Mode
01:50:19.6 05/09/2012: Reading MAME hall of fame
01:50:20.4 05/09/2012: Shutting down display
01:50:20.6 05/09/2012: Setting Up RawInput Hook
01:50:20.7 05/09/2012: Launching RawInputHook.exe
MAME is either immediately minimised, or I see a few seconds of a MAME game before all I can see is the Windows taskbar.
I press alt-tab
I can't quickly install GameEx and some MAME roms onto another machine, it'll take a bit of time to do...
I should clarify that this doesn't happen if GameEx is run manually. I have also made a .bat that delays GameEx from starting on windows startup for a few minutes, but it makes no difference.
I've managed to find and try a different video card in the same setup, it doesn't have this problem.
Problem card: Radeon HD 4650 / Catalyst 12.6
Solution card: Radeon X1800 XT / Catalyst 10.2
I'll mark as resolved as there are more worthy threads.
Edited by Draco1962
