Just installed GameEx 5.55 on my new arcade cabinet box and cannot seem to get it to run.
decription of problem (cant get the log files as i am at work)
open application
sit there for a couple mins until the splash screen goes away :(
hear the first half second of the start up music.
crashes out to the gameex debug log
the debug log complains at the end about direct x errors for some reason. looks to be gfx related.
running dxdiag i am running 9.0c and all the test run fine.
any ideas?
(i'll try to post the actual log soon but its not actually on the network yet so cant access it at the moment)
a
open application
any ideas?
a
Yep, need the log and info on the system.
15:31:29.2 17/02/2006: GameEx: Version 5.55: Starting Log
15:31:29.4 17/02/2006: Operating System Platform: Win32NT
15:31:29.4 17/02/2006: Operating System Name: Windows XP
15:31:29.4 17/02/2006: Operating System Version: 5.1.2600
15:31:29.4 17/02/2006: Checking for versions of .net Framework installed
15:31:29.4 17/02/2006: .net Framework 1.1 Installed
15:31:29.4 17/02/2006: Checking Registration
15:31:29.4 17/02/2006: Running Randomize()
15:31:29.4 17/02/2006: Initialising Video/MNG DLL's
15:31:29.5 17/02/2006: Running Misc startup tasks
15:31:29.5 17/02/2006: Setting Menu types
15:31:29.5 17/02/2006: Opening Configuration File
15:31:29.5 17/02/2006: Getting Configuration Values
15:31:29.6 17/02/2006: Using Theme: Default - GameLauncher
15:31:29.6 17/02/2006: Checking for alternate Image Directory for Theme: Default - GameLauncher
15:31:29.6 17/02/2006: Text/Language: English
15:31:29.6 17/02/2006: Applying Language/Text
15:31:29.7 17/02/2006: Creating Scancodes.txt (List of DirectInput scan codes)
15:31:29.7 17/02/2006: Snap Delay set to: 1
15:31:29.7 17/02/2006: Is Media Center running?
15:31:29.7 17/02/2006: Check Media Center Exit/Start Mode
15:31:29.7 17/02/2006: Media Center Mode 0
15:31:29.7 17/02/2006: Checking for applications to Launch On Startup
15:31:29.7 17/02/2006: Get other settings
15:31:29.8 17/02/2006: Using 2D Animations
15:31:29.8 17/02/2006: Desktop set to Hide ICONS and set Background to Black
15:31:29.8 17/02/2006: Backing up Registry Wallpaper Settings
15:31:29.8 17/02/2006: Set: Find emulator artwork on best match basis
15:31:29.8 17/02/2006: Launching HideOS.exe
15:31:31.1 17/02/2006: Hiding Taskbar
15:31:31.1 17/02/2006: Start work for Form
15:31:31.1 17/02/2006: Getting Original Screen Size
15:31:31.1 17/02/2006: Loading ICON
15:31:31.2 17/02/2006: Initializing Component
15:31:31.2 17/02/2006: Initialising Bass Audio Library
15:31:31.7 17/02/2006: Loading default loading screen
15:31:31.7 17/02/2006: Arcade Mode is on
15:31:31.7 17/02/2006: Using General Font: HandelGothic BT
15:31:31.7 17/02/2006: Using Title Font: HandelGothic BT
15:31:31.7 17/02/2006: Initialising DirectDraw
15:31:31.9 17/02/2006: Creating DirectDraw Device
15:31:32.1 17/02/2006: Setting Resolution to 800x600 32 bit color
15:31:32.1 17/02/2006: Creating DirectDraw Surfaces
15:31:32.1 17/02/2006: Creating Primary Surface - Full Screen Mode
15:31:32.1 17/02/2006: Creating Back Buffer
15:31:32.3 17/02/2006: Loading graphic surfaces
15:31:32.4 17/02/2006: Creating Surfaces Misc and Dialogs
15:31:32.5 17/02/2006: Creating Surface Volume
15:31:32.5 17/02/2006: Creating Surfaces Arrows
15:31:32.5 17/02/2006: Creating Surfaces GameEXlogo Text
15:31:32.5 17/02/2006: Creating Surfaces Toolbar
15:31:32.6 17/02/2006: Creating Surfaces Backgrounds
15:31:32.7 17/02/2006: Creating Surfaces Toolbar Controls
15:31:32.8 17/02/2006: Creating Surfaces GameEx Logo
15:31:32.8 17/02/2006: Creating Surfaces Home & Exit
15:31:32.9 17/02/2006: Creating Surfaces Snaps
15:31:32.9 17/02/2006: Creating Surfaces Menu and List Bars
15:31:33.1 17/02/2006: Creating Fonts
15:31:33.1 17/02/2006: Creating Menu Font
15:31:34.5 17/02/2006: Creating Game Font
15:31:35.7 17/02/2006: Creating Game Font Standard Size
15:31:36.9 17/02/2006: Creating Font Black
15:31:37.0 17/02/2006: Creating Font Black Small
15:31:37.2 17/02/2006: Creating Game Font Faded
15:31:38.4 17/02/2006: Creating Title Font
15:31:39.7 17/02/2006: Creating Control Panel Font
15:31:40.9 17/02/2006: Fonts Created Succesfully
15:32:03.0 17/02/2006: MAME Path is: M:\emu\Mame
15:32:03.0 17/02/2006: MAME EXE file is: mame32p.exe
15:32:03.0 17/02/2006: ROM Path is: M:\emu\Mame\ROMS
15:32:03.0 17/02/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
15:32:03.0 17/02/2006: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
15:32:03.0 17/02/2006: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
15:32:03.1 17/02/2006: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
15:32:03.1 17/02/2006: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
15:32:03.1 17/02/2006: Loading Controls.ini map file
15:32:03.1 17/02/2006: Loading Custom Emulators
15:32:03.5 17/02/2006: Snap Path is: M:\emu\Mame\snap
15:32:03.5 17/02/2006: AVI Snap Path: Not Found
15:32:03.6 17/02/2006: Flyer Path is: M:\emu\Mame\flyers
15:32:03.6 17/02/2006: Cabinet Path is: M:\emu\Mame\cabinets
15:32:03.6 17/02/2006: Title Path is: M:\emu\Mame\titles
15:32:03.6 17/02/2006: Panel Path: Not Found
15:32:03.6 17/02/2006: Icon Path is: M:\emu\Mame\icons
15:32:03.6 17/02/2006: Marquee Path is: M:\emu\Mame\marquees
15:32:03.6 17/02/2006: MAME CMD options: -triplebuffer -nowindow -joy
15:32:03.6 17/02/2006: Attempting to load game list
15:32:03.7 17/02/2006: Loading last used Game List
15:32:03.7 17/02/2006: Setting Music Volume
15:32:03.7 17/02/2006: Cannot Load Play List. Check Path and filename
15:32:03.7 17/02/2006: Creating DirectSound Device
15:32:03.7 17/02/2006: Trying: Primary Sound Driver
15:32:03.7 17/02/2006: Loading Sound Files
15:32:03.8 17/02/2006: DirectSound Device Created Successfully
15:32:03.8 17/02/2006: Creating ICONS
15:32:04.2 17/02/2006: Gamepad/Joystick disabled
15:32:04.2 17/02/2006: Playing intro sound file
15:32:04.2 17/02/2006: Initializing MCE Remote
15:32:04.3 17/02/2006: Initialization OK! Starting GameEx!
15:32:04.3 17/02/2006: Testing Main Loop Once: Processing Frame
15:32:04.6 17/02/2006: ERRORS DETECTED: EXITING
15:32:04.7 17/02/2006: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
15:32:04.7 17/02/2006: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
15:32:04.7 17/02/2006: at GameEx.GameEx.mainform.DisplayFrame()
What sort of video card do you have? This sort of error normally means your video card is not up to the job.
Things to try are:
Use a different resolution or have GameEx not set the resolution.
Use a different theme.
Use a different video card.
Dont use advanced GFX.
Use 16 bit colour.
Things to try are:
Use 16 bit colour.
its a crappy built in something or another.. sis i think. i've allocated 64mb of system mem to it in the bios.
i've already tried diff rez and for gameex not to change rez
dont have any other gfx card to use .. this gfx is fine for mame and thats all i need it for.
advanced gfx?
i'll try 16bit but i think i had it on 16bit when i first installed it.
advanced gfx?
I think you might be out of luck without a better video card. Sorry.
