Hi,
First of all, thanks for this excepcional frontend. I've been using it for a couple of years now.
I've got a doubt about configuring Dolphin Emulator. I've got a few WII games and play them with my wiimote and nunchuck. As you may know, there are some games that need to be played with the wiimote turned sideways and no nunchuk attached. My question is, is there any way of getting an automatic controller config for each kind of game or I'll have to create two categories inside Gameex, one being WII games side controller and the other WII games wiimote+nunchuck?
Thanks so much.
What I do (and someone may have a better way) is keep 2 EXEs configured seperately, and seperate the games into two different folders depending on the controller config (although I use a map file and keep my games in the same directory). Then I add both to a group within GameEx so they're both in the same list.
Titanusss.
If you're using Wiimote controlers on Dolphin, you don't need to worry about the wiimote position.
You only have to worry about that when using standard joysticks, so you have to emulate wich position the game controler is.
I should have mentioned that I don't use Wiimotes. :)
Edited by Draco1962
