Hi all.
It's been a while since I posted anything but I've recently started tinkering with a media PC and adding GameEx to it.
After setting up Project 64 1.7 I was rather surprised to see that it doesn't have a global widescreen stretch option (I'd never noticed this before as I was always on a 4:3 arcade monitor)
You either have to live with the black borders at each side or manually change the setting for each game.
So I started digging in the Project64.cfg and seen that it adds an entry for each game when you change this setting.
It stores the CRC1+CRC2 for each game.
Thanks to the Muppen ini I found a list of 2522 CRC1+CRC2's so I've created a new Project64.cfg that enables widescreen stretching for pretty much every game. Thought I would fire it up here as it might be useful to other users.
Bear in mind the attached cfg is my config so you will have to edit all your settings again.
If you don't want to do this just copy all the:
[001A3BD0-AFB3DE1A-C:46]
Direct3D8-DesiredAspect=1
type entries from the bottom of the attached config and paste them into your own
Project64.zip
  • Like 6
Thanks for the share Stu!
Wow !
Thanks for this Stu.
Last week I ran into the same problem.
I've noticed what you said in the config file, each game has to be setup for wide or streetch.
This will help me a lot !
Thanks!
