Mame Shows All Of my roms in game ex but the two chds that i have killer instinct 1 & gold they show up in mame but not gameex plz help
If you recently added those 2, you'll need to rebuild your MAME game list. Just scroll down and click on Update List. That should add them.
I think Han is on to something there, but if you update your MAME list and those games still aren't displaying, please post a copy of your MAME config (or GameEx.ini). It could also be that filter settings are preventing these games from displaying.
where would i put the path?
First of all, we are working in you MAME roms folder. Inside this folder, you need to create a folder with the same name of the rom. For example, for Killer Instinct (rom named kinst.zip), create a new folder in MAME\roms\ labeled "kinst" (MAME\roms\kinst\). Put your chd file (uncompressed) there, and you'll should be fine.
That may work, however I used to have mine in a separate folder Mame\chds.
In GameEx, you can set more than one path for the roms. P:\Mame\roms;P:\Mame\chds
