--DAPHNE version 0.99.7
--Command line is: Daphne.exe lair2 vldp -fullscreen -x 640 -y 480 -nohwaccel -framefile d:\daphne\DL2_framefile.txt
--CPU : GenuineIntel 2800 MHz || Mem : 1280 megs
--OS : Windows XP/.NET || Video : RADEON 9600 SERIES
Setting screen width to 640
Setting screen height to 480
Set 640x480 at 32 bpp with flags: 80000000
Initializing sound system ...
Joystick #0 was successfully opened
Remapping input ...
Loading ./roms/lair2/dl2_319.bin ... 65536 bytes read into memory
Could not open framefile : d:\daphne\DL2_framefile.txt
You must specify a -framefile argument when using VLDP.
If you didn't, then this is the problem. :)
Could not initialize laserdisc player!
Shutting down sound system...
Shutting down video display...
this is my log file froom daphne i have all my laser games running okay though daphne loader but when i try to set up daphne in game ex it wont load i tihkn it has sometihng to do with where game ex is trying to find my frame files??? but for the life of me cant see what im doing wrong any help would be great thanks
the jester
