I recently upgraded a whole bunch of stuff in my PC. When I started it up, I got the blue screen of death and had to reinstall windows. Thankfully I saved all of my files, but it appears I may end up having to reinstall a few programs that didn't copy over correctly. I do understand what's going on with Gameex, as I am getting the nag screen. I had a reg key sent through email when I purchased the lifetime updates. I saved the email, but it won't open the file for some reason. It says windows doesn't know the file type and just lists it as unknown. I am pretty sure I will just need to reinstall Gameex, mainly because it's now just bringing me straight to the gameex website (odd). I am wondering if I can just reuse the reg key and if someone knows what type of file I can direct windows to. I assume I need a new reg key.
I emailed Tom about the issue at [email protected], then at [email protected]. I am wondering if these are the correct avenues to reach him about this issue.
Thats fine you have the correct addresses. Also, you may want to change the file extention to REG. Then import it into your registry. If it still does not work Tom will need to send you a new key. Some older users had to get new keys when they upgraded to 64bit.
Yeah, I didn't upgrade windows or my HD. I changed out my MB, processor power supply and video card. I'm loving the GTX 460. I think I probably copied over the program files incorrectly or something. I'll look into the reg key thing, thanks!
