I started trying out different views by clicking change view. However, when I went to one of the views - something (perhaps a video) is not liked by GameEx and it's crashes everytime I open that emulator. The view setting is saved, so I can't ever go in and change it. Is there any way to reset the view for a particular emulator (or all of them) to default (in a text file)? I'm on the default theme.
Any help would be appreciated - thanks.
18:53:56.1 6/19/2012: Not Restoring Emulator Database From Cache: 4
18:53:58.7 6/19/2012: 21 Consecutive Exceptions Occured
18:53:58.8 6/19/2012: Object reference not set to an instance of an object.
18:53:58.8 6/19/2012: at Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, Rectangle SrcRect, Byte Alpha, Byte Red, Byte Green, Byte Blue, Single Rotation)
18:53:58.8 6/19/2012: at Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, Rectangle SrcRect, Byte Alpha)
18:53:58.8 6/19/2012: at Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, RectangleF SrcRect, Byte Alpha)
18:53:58.8 6/19/2012: at GameEx.GameEx.mainform.a(Int32 A_0, Int32 A_1, String A_2, Boolean A_3, Boolean A_4, Int32 A_5, Int32 A_6)
18:53:58.8 6/19/2012: at GameEx.GameEx.mainform.i(Boolean A_0)
18:53:58.8 6/19/2012: at GameEx.GameEx.mainform.f(Boolean A_0, Boolean A_1)
18:53:58.8 6/19/2012: at GameEx.GameEx.mainform.du()
18:53:58.8 6/19/2012: Trying reinitialising the display after sleeping for 4 seconds
18:53:58.8 6/19/2012: Exception count will be dropped to 15
18:54:05.9 6/19/2012: --**--
18:54:05.9 6/19/2012: 21 Consecutive Exceptions Occured: Exiting
18:54:05.9 6/19/2012: Closing database connection
18:54:06.0 6/19/2012: First Exception:
18:54:06.0 6/19/2012: Object reference not set to an instance of an object.
18:54:06.0 6/19/2012: at Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, Rectangle SrcRect, Byte Alpha, Byte Red, Byte Green, Byte Blue, Single Rotation)
18:54:06.0 6/19/2012: at Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, Rectangle SrcRect, Byte Alpha)
18:54:06.0 6/19/2012: at Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, RectangleF SrcRect, Byte Alpha)
18:54:06.0 6/19/2012: at GameEx.GameEx.mainform.a(Int32 A_0, Int32 A_1, String A_2, Boolean A_3, Boolean A_4, Int32 A_5, Int32 A_6)
18:54:06.0 6/19/2012: at GameEx.GameEx.mainform.i(Boolean A_0)
18:54:06.0 6/19/2012: at GameEx.GameEx.mainform.f(Boolean A_0, Boolean A_1)
18:54:06.0 6/19/2012: at GameEx.GameEx.mainform.du()
18:54:06.0 6/19/2012: Last Exception:
Yes, I'm sure there is. Specific views for every page are stored in GameEx.ini. When I was experimenting with GameEx, I found these entries, but now I don't have them, since I actually resetted my views.
If you want to attach your GameEx.ini, we coluld take a look and tell you what to delete to reset views to their defaults.
Regards, Alpha.
