I am new to GameEx, hello everybody!
I am experiencing a black screen right after the nag screen (I _will_ donate right after it's up and running :-). I have installed GameEx properly, but even after a new install it's just the same. I have attached the log file and the current GameEx ini (in which I haven't made too many modifications after my last reinstall).
Please also note that the MAME paths in the GameEx.ini and the Log file differ - which seems odd to me. The MAME path in the GameEx.ini is the right one and I can start Mame properly on the command line from that location. The path in the Log file is an old path where there is no current Mame installation anymore. Probably a hint at the black screen...
Thanks very much for helping me out (and sorry in advance if that should turn out to be a dumb question...)
Cheers
Log File
21:26:14.9 19.06.2012: Opening Configuration File
21:26:15.0 19.06.2012: GameEx: Version 12.67: Starting Log
21:26:15.0 19.06.2012: Operating System Platform: Win32NT
21:26:15.0 19.06.2012: Operating System Name: Windows Vista
21:26:15.0 19.06.2012: Operating System Version: 6.0.6002
21:26:15.0 19.06.2012: Aero running
21:26:15.0 19.06.2012: Initializing Vista/Windows 7 volume control
21:26:15.0 19.06.2012: Intel® Core™2 Duo CPU T5800 @ 2.00GHz, 3066MB
21:26:15.0 19.06.2012: 2Ghz - 2 Cores or CPU's
21:26:15.0 19.06.2012: Running Randomize()
21:26:15.0 19.06.2012: Loading PlugIns
21:26:15.0 19.06.2012: Checking for applications to Launch On Startup
21:26:15.0 19.06.2012: Running Misc startup tasks
21:26:15.0 19.06.2012: Setting Menu types
21:26:15.0 19.06.2012: Getting Configuration Values
21:26:15.0 19.06.2012: Using Theme: Default - Default
21:26:15.0 19.06.2012: Checking for alternate Image Directory for Theme: Default - Default
21:26:15.0 19.06.2012: Initialising Video/MNG DLL's
21:26:15.0 19.06.2012: GameEx will check for media insertion (may affect performance)
21:26:15.0 19.06.2012: Is Media Center running?
21:26:15.0 19.06.2012: Checking/Creating LCD Registry values
21:26:15.0 19.06.2012: Check Media Center Exit/Start Mode
21:26:15.0 19.06.2012: Media Center Mode 2
21:26:15.1 19.06.2012: Video previews on. Warning: Only recommended on modern systems
21:26:15.1 19.06.2012: Snap Delay set to: 2
21:26:15.1 19.06.2012: Get other settings
21:26:15.1 19.06.2012: Desktop set to Hide ICONS and set Background to Black
21:26:15.1 19.06.2012: Set: Find emulator artwork on best match basis
21:26:15.1 19.06.2012: Start work for Form
21:26:15.1 19.06.2012: Getting Original Screen Size
21:26:15.1 19.06.2012: Opening Database Connection
21:26:15.1 19.06.2012: Initializing Component
21:26:15.2 19.06.2012: MAME Path is: C:\Users\mittag\_Privat\Videogames\9_Emulatoren\MAME0146
21:26:15.2 19.06.2012: Cannot Find MAME Path: MAME Disabled
21:26:15.2 19.06.2012: Loading Controls.ini map file
21:26:15.2 19.06.2012: Applying Language/Text
21:26:15.2 19.06.2012: Text/Language: English
21:26:15.3 19.06.2012: Loading Custom Emulators
21:26:15.3 19.06.2012: Loading Emulator 1: Atari 5200
21:26:15.3 19.06.2012: Loading Emulator 2: Nintendo SNES
21:26:15.3 19.06.2012: Loading Emulator 3: Nintendo N64
21:26:15.3 19.06.2012: Using Version 3 Themes Animations
21:26:15.3 19.06.2012: Retrieving resolution setting
21:26:15.3 19.06.2012: Using General Font: Trebuchet MS
21:26:15.3 19.06.2012: Using Title Font: Trebuchet MS
21:26:15.3 19.06.2012: GameEx will try to reduce CPU usage
21:26:15.3 19.06.2012: Initialising Direct3D
21:26:15.4 19.06.2012: Creating Surfaces
21:26:15.9 19.06.2012: Creating Primary Surface - Windowed Mode
21:26:15.9 19.06.2012: Creating Back Buffer
21:26:15.9 19.06.2012: Loading graphic Surfaces
21:26:15.9 19.06.2012: Display is running at: 1280x800 32bit color, 60hz
21:26:15.9 19.06.2012: Adapter: ATI Mobility Radeon HD 3400 Series
21:26:15.9 19.06.2012: Max texture size: 8192x8192
21:26:15.9 19.06.2012: Available texture memory: 1527MB
21:26:15.9 19.06.2012: Initialising Bass Audio Library
21:26:16.0 19.06.2012: Creating Surfaces Misc and Dialogs
21:26:16.5 19.06.2012: Creating Surfaces Volume
21:26:16.5 19.06.2012: Creating Surfaces Arrows
21:26:16.5 19.06.2012: Creating Surfaces GameEXlogo Text
21:26:16.5 19.06.2012: Creating Surfaces Toolbar
21:26:16.5 19.06.2012: Creating Surfaces Toolbar Controls
21:26:16.5 19.06.2012: Creating Surfaces Backgrounds
21:26:16.5 19.06.2012: Creating Surfaces GameEx Logo
21:26:16.5 19.06.2012: Creating Surface Unselected
21:26:16.5 19.06.2012: Creating Surfaces Snaps
21:26:16.5 19.06.2012: Creating Surfaces Menu and List Bars
21:26:16.8 19.06.2012: Creating Fonts
21:26:16.8 19.06.2012: Creating Game Font
21:26:17.0 19.06.2012: Creating Game Font Faded
21:26:17.0 19.06.2012: Creating Title Font
21:26:17.1 19.06.2012: Restoring Title Font From Cache
21:26:17.2 19.06.2012: Creating Font Black
21:26:17.3 19.06.2012: Creating Font Black Small
21:26:17.4 19.06.2012: Fonts Created Succesfully
21:26:17.4 19.06.2012: 1MB Video Memory Used
21:26:40.8 19.06.2012: MAME CMD options: -nowindow -joy -skip_gameinfo
21:26:40.8 19.06.2012: Creating DirectSound Device
21:26:40.8 19.06.2012: Trying: Primärer Soundtreiber
21:26:40.8 19.06.2012: Loading Sound Files
21:26:40.8 19.06.2012: DirectSound Device Created Successfully
21:26:40.8 19.06.2012: Initialising DirectInput for Gamepad support
21:26:40.9 19.06.2012: Unable to create a joystick device
21:26:40.9 19.06.2012: Loading Start Page
21:26:40.9 19.06.2012: Initializing MCE Remote
21:26:40.9 19.06.2012: Playing intro sound file
21:26:41.0 19.06.2012: Initialization OK! Starting GameEx!
21:26:41.0 19.06.2012: Testing Main Loop Once: Processing Frame
GameEx.ini
[General]
Xresolution=800
Yresolution=600
DisplayOnSecondary=False
MAMEPath=C:\Emulators\Mame32
MAMEEXE=Mame32.exe
ROMPath=C:\Emulators\Mame32\roms
StartWait=False
USeAdvanceMame=False
AdvanceMAMEEXE=advmame.exe
AdvanceMAMEPATH=C:\Emulators\AdvanceMAME
ADVANCEMAMEOptions=-device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
UseZinc=False
ZincEXE=zinc.exe
ZincPATH=C:\Emulators\ZiNc
ZincOptions=--renderer=.\renderer.znc
Font=Trebuchet MS
TitleText=MAME Games
OnlyWorking=True
AllowImperfect=True
VerifyRoms=True
OnlyRoms=False
NoGameInfo=False
GameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;Hardware;Spanish;(Easy;(harder
GameFilterOn=True
NoAdult=True
NoClones=False
MameOptions=-nowindow -joy -skip_gameinfo
ArcadeMode=False
UseLargeFonts=True
SnapPath=C:\Emulators\Mame32\snap
AVISnapPath=C:\Emulators\Mame32\avisnap
AVIFrameSkip=0
flyerpath=C:\Emulators\Mame32\flyers
cabinetpath=C:\Emulators\Mame32\cabinets
CatverLocation=\DATA\catver.ini
nplayerslocation=\DATA\nplayers.ini
HistoryLocation=\DATA\history.dat
InfoLocation=\DATA\mameinfo.dat
CommandLocation=\DATA\command.dat
ShowGameInfoPage=True
EnableStartPage=True
ShowStartPageFirst=True
skipintro=False
AntiAliasFonts=True
OutlineFonts=False
DisplayBackgroundImage=True
SnapBrightness=120
MusicPlayList=C:\Music
MusicVolume=100
MediaCenterMode=2
PlayIntroSound=True
AttractModeTimer=4
AttractModeAudio=2
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=True
NoWaitVSync=False
Sleep=True
HideUpdateList=False
DisableExit=False
HideShutDown=False
StartUpVideo=C:\Video
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
FontSize=0
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
DisableEscape=False
DisableRemoveGame=False
theme=Default - Media Center
Language=English
FlatStartPage=False
DontSwitchRes=True
SnapDelay=2
AllowWindowResize=True
ShowLoadingScreen=True
Use16BitColour=False
Widescreen=False
DisableMAME=False
ShellBeforeLaunch=
ShellOnExit=
EnableJukeBox=True
jukeboxplaylist=Live! (CD1)
EnableMediaControls=True
ShufflePlayLists=True
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=True
TitleFont=Trebuchet MS
DialogTextWhite=False
TimeFormat=True
HideToolBar=3
DoNotFilterROMS=pacman;splatter
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=True
MarqueePath=C:\Emulators\Mame32\marquees
PanelPath=C:\Emulators\Mame32\cpanel
TitlePath=C:\Emulators\Mame32 itles
ICONPath=C:\Emulators\Mame32\icons
CPEnabled=True
CPPATH=\DATA\controls.ini
ShowVector=True
ShowNeoGeo=True
ShowOriginal=True
ShowAdult=True
ShowCPS=True
ShowVertical=True
ShowHorizontal=True
EnableFavorites=True
ShowMulti=True
ShowAllMAME=True
ShowLastGame=True
ShowRandomGame=True
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=True
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=False
HideCreateSnaps=False
HideLogoff=False
HideStandBy=False
DisableMouse=False
ShowVideos=True
VideoPath=
EnableAlphaPage=True
EnableJoystick=True
EnableSlikStik=False
KeyboardDirectInput=False
NoMahjong=True
VIDEOFFDSHOW=0
JoystickDevice=
EnableCustomInput=False
EnableCustomJoyInput=False
AttractVideosEnabled=True
AttractVideosRatio=1
AttractVideosPath=C:\Video
AtractModeNewGameTimer=2
AdvancedGFX=True
HideZinc=False
TransitionType=0
Bypass=True
DontBlitWait=False
ShowMostPlayed=True
ExcludedMAMERoms=
DeadZoneX=0
DeadZoneY=0
JukeBoxMode=0
AmbienceFile=L:\-DATA-\-MP3-\4 Non Blondes\4 Non Blondes - What's Up.mp3
AmbianceFile=C:\arcade.mp3
EnableAmbiance=False
HIDEDESKTOP=True
UseSnapBestMatch=true
IngameVK=121
EnableThemePicker=True
DisablePleaseWaitAnimation=False
EnableRipCD=True
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=False
rotateplus90=False
ShowButtons=True
DisplayTitleText=True
PlayExitSaverSound=False
ShowAtari=True
ShowGolden=True
ShowHorizVert=0
UseModel2=False
Model2PATH=C:\Emulators\Model2
ShowModel2=True
ShowLightGun=True
EnableBezel=True
AutoUpdate=1
NoMAMEOnStartPage=False
HideRestart=False
EnableStartScreenSaver=True
SortMAMEThE=True
SortEmuThE=True
ShowMCEEXport=True
NoRotationRestrictions=False
MakeToolbarTextWhite=False
ExitGameAfter=0
ShowTrackball=True
ShowSpinner=True
LoadEmusOnThread=True
LoadRadioOnThread=False
StartPageAni=True
EmusAttractMode=False
MuteEmuAttractMode=False
Show4Player=True
CabControlFriendly=False
ManualPath=C:\Emulators\Mame32\manuals
HideShowTaskbar=True
CustomMAMEFolderPath=C:\Emulators\Mame32\CustomFolders
MAMEFavoritesini=C:\Emulators\Mame32\Folders\Favorites.ini
MenuFontSameSize=False
PreviewVideos=2
ShowStatistics=True
DisableMouseWheel=False
ErrorReporting=0
ReduceCPU=True
ShowNotPlayed=True
(and so on)
Check your registry, probably there are leftovers of your old MAME installation that are causing the conflict... In fact, I guess that the discrepancy is the cause of your issue, as you already noted...
Maybe you have GameEx installed in more than one place? Do a search for gameex.exe and see if more than one exe pops up.
:EDIT: Dang, Tom beat me! LOL!
Right on the spot, guys!
For whatever reason I had a second GameEx.ini deep down in ~user\AppData\Local\VirtualStore (and so on) and that one had the wrong paths in it. Only one GameEx.exe though.
Thanks very much for helping me out!
Does this mean that GameEx looks for another location than CONFIG\GameEx.ini before searching in what should be the default folder? :huh:
