ROM Managers, Renamers & Dats
CLRMame Pro
A popular ROM management program. Designed to help you maintain and organize your emulators roms collection for various gaming systems.
ROM Center
Another popular ROM management program.
OfflineList
Another ROM manager.
ROMSorter
A program that can sort ROMs based on flags in the filename Eg. Sorting all US (U) and Japanese (J) ROMs.
MAME Content Manager
It's a simple program that makes it easy to control what types of ROMs you keep on your PC. MCM lets you easily rename or delete all MAME ROMs and data files by category - Adult, Quiz, Mahjong, Puzzle, etc.
ROMLister
Use this tool to locate MAME ROMs that will play on your machine.
ROMDeleter
Do you have 100000s of roms that have been renamed using TOSEC and Good Tools? If so then you probably have GBs of extra roms such as bad dumps, overdumps and unwanted translations. Use this free app to delete them from your collection using filters.
UnGoodMerge
This program makes it very convenient to convert a large amount of GoodMerged 7-Zip archives into formats that emulators can read.
GoodTools
GoodTools is a common name for set of Rom Renamers for a wide variety of systems. Created by Cowering, they are distributed as .exe files with a built in database. The GoodTools are some of the oldest rom renamers still in existance.
NoIntro
What "No-Intro" does is fill some .dat files, to be used with ROM-Managers, with information about the known ROMS released.
TOSEC
TOSEC is an acronym standing for "The Old School Emulation Centre", and is the name of an organisation dedicated to creating a database project, cataloguing the complete software libraries of old computer and console platforms.
Redump
A great source for disc verification DATs.
Maybe-Intro
Maybe-Intro is a project dedicated to the preservation and cataloging of ROM hacks and especially the fan translations of video games.
Input Mapping Software
AutoHotkey
Automate your applications. Maybe used for these games, that have trouble to get working in a cabinet (most wrappers seen to made in this utility)
AutoIt
Powerful scripting application that can be used to write wrappers. Can compile custom scripts to executables.
Joy2Key
Program to simulate keypresses from joystick inputs (useful for some emulators)
PPJoyKey
PPJoyKey is an application to convert keystrokes into Windows joystick input via the PPJoy Virtual Joystick interface.
VJoy Virtual Joystick
VJoy Virtual Joystick is a software application and virtual driver system that allows keyboard input to be translated to joystick input.
J2K - A Joystick to Keyboard Mapper
There are already very feature-rich joystick to keyboard mappers out there, be it JoyToKey or XPadder. However, both are not Freeware and both lack the possibility to easily switch configurations from outside the applications, which would be necessary if you use game front-ends like GameEx.
XPAdder
Great software for keyboard and mouse emulation. (By Jonathan)
Mame Analog Joystick Map Editor
This is a Mame analog joystick map editor. Loads/Saves Mame ini files that can specify analog control map for specific games. Some example ini files included. Save the ini files to the Mame's ini folder (create one if it's not there). Name the file [ROM].ini. (By HeadKaze)
Timer (HyperAttract)
This is a application to auto quit your emulator under a amount of idle, which you define in the ini file.
Pinnacle Game Profiler
Pinnacle Game Profiler is a keyboard keymapper, mouse emulator, game manager, and input device programmer—all rolled into one.
List Generators
Mame LCDGen
LCD text file generator for creating *.lcd files to send to a LCD attached to your PC's com port, typically used in a Mamecab in conjunction with a frontend. (By Silver)
ListGen
This utility uses a free SQL engine (SQLite) to create an internal table from MAME's -listxml output that can be used to generate MAMEWah game lists. It also can be used to generate batch files for Cakemeister's MAME Movie Maker. ListGen is a fast, open source way to filter game lists. (By Cakemeister)
ROMLister
A windows GUI based application that also uses MAME's xml output file to allow you to create custom filtered lists of games based on your input criteria. (# of buttons, joystick type, monitor orientation, etc) The program can create numerous output files for many popular front ends as well as generic formats like XML, CSV, and batch files. Open source and freeware. (By NOP)
MultiMame
MultiMAME is a command line application which makes multiple emulators and/or subset of games look like a single emulator. (By Lilwolf)
RomDir2XML
Utility for generating MaLa game lists for emulators other than MAME. (By Spiderstyle)
CFG Magician
Create Custom Mame Cfg Files Automatically. (By Morpheus)
Video Tools
MultiRes
Program to change the screen resolution (inc. from a commandline)
UltraMon
UltraMon is a utility for multi-monitor systems, designed to increase productivity and unlock the full potential of multiple monitors.
PowerStrip
Program for setting custom resolutions. See Custom display modes (Windows) - Powerstrip
MAME Resolution Tool
Tool for generating cfg files with resolutions to match closest authentic resolution for games. (By MinWah)
AvRes
Another tool for generating cfg files with resolutions to match closest authentic resolution for games. (By Gavin Benson)
Soft-15k
A simple tool programming videocard drivers to support 15 Khz AND arcade resolutions. Supports ATI Catalyst, NVidia ForceWare, Matrox PowerDesk and various 3Dfx Voodoo3/4/5 drivers. See Soft-15khz. (By SailorSat)
iRotate
iRotate uses the hardware rotation capabilities of the video card to rotate the screen.
softSpin
softSpin's screen orientation support utilizes the rotation capabilities present in most of today's graphics card drivers.
mng2avi
The mng2avi is a utility which converts MNG video files into AVI video files. It does this by first breaking down the MNG file into a series of pngs, then running a VirtualDub script to create the AVI file. Optionally, mng2avi can be used to create demo loop movies directly from MAME's MNG output. (By Cakemeister)
mng2avi
Another mng2avi program. (By Silver)
Audio Tools
CabVol
Control volume with your spinner/trackball/joysticks/buttons. (By Ahofle)
VolumeTray
This little utility lets me map a single button/control on my control panel for Volume up and down that works regardless of emulator.
Command Line Volume
Run this utility before and after you run an emulator and it will restore the volume last set for it. (By HeadKaze)
Master Volume Lock/Fix
Run this script on system startup to lock the sytem volume at a given level. (By Kelroy)
Ambience
Ambience runs in the system tray to play audio samples randomly or in order. While designed to play the Arcade Ambience samples it can play any samples on a primary or secondary sound card. (By TheShanMan)
SoundSwitch
SoundSwitch makes it easier to switch playback devices (sound cards).
Quick Sound Switch
Quick Sound Switch makes it easier to switch playback devices (sound cards).
Control Panel Software
Johnny 5
Johnny5 is a label layout program, controls viewer, and artwork generator. You take your own background image and add where you want your labels to go, such as Up, Fire, etc. Johnny then takes information from controls.dat to populate the labels and creates a psudeo-interactive display from it. Optionally, Johnny can just save the display to a file via command-line. J5 can also display instruction cards, control panel images and supports the command.dat. Johnny also includes a GUI. (By Howard Casto)
You can find full information about Johnny 5 controls viewer here
Johnny 5 home page
CPMaker
CPMaker is a label layout program, control panel layout program, controls viewer, and artwork generator. The CPMaker GUI, which was released in February 2006, allows the user to easily create his or her own control panel out of artwork pieces. (By Cakemeister)
CPMaker home page
CPViewer
CPViewer is a label layout program and controls viewer.
jcrouse says this about what CPViewer is:
"CPViewer is an add-on for Mame. More specifically for the front-end you use to launch your Mame games.
It uses a file called controls.ini (part of controls.dat) to lookup the controls for a particular game. 'It then displays them on the screen so you know what buttons and movements perform what actions in the game that is currently highlighted in your front-end.
Did you ever sit do to play a little and decide to try a new game? Then ask yourself, "What buttons do what?"
Well if the game has been documented in the controls.ini file, this won't happen again. Simply press a hotkey (one of your control panel buttons) and a graphic of your control panel will be displayed with all of the character movements or button assignments displayed so you know what buttons perform what actions. It's that simple." (By John Crouse)
home page
CPWizard
CPWizard is a control panel editor, control panel (controls.dat), game info (listinfo.xml/Catver.ini/nplayers.ini/HallOfFame.xml), game history (history.dat), mame info (mameinfo.dat), special moves (command.dat) and hiscore (story.dat) viewer.
CPWizard is a CP editor and viewer with a graphics library designed to build a custom CP. It runs resident in the icon tray and can be invoked by pressing pause in Mame without the need for command line options. It can export CP as images or bezel artwork that can be toggled on or off inside Mame. It also supports emulators other than Mame. (By HeadKaze)
CPWizard Home Page
LED Software
LEDBlinky w/ Animation Editor
Arcade LED Control software and Animation Editor. Supports LED-Wiz, PacLED64, PacDrive, and U-HID lighting and output controllers. (By Arzoo)
LEDWiz SDK
LEDWiz SDK. (By RandyT / MikeQ / HeadKaze)
PACDrive & U-HID SDK
PACDrive & U-HID SDK. (By HeadKaze)
LuminAudio Engine™
LuminAudio Engine™ is a "light organ" application for the LED-Wiz and LED-Wiz+GP Lighting and output controllers. (By RandyT)
LuminAudio Engine™ FE Integration Scripts
Scripts to help integrate the LuminAudio Engine™ software for use in Front Ends. (By AlexDog69)
Front-End / Jukebox Plugins
Arcade LED Control software and Animation Editor (LWAX format). Supports LED-Wiz, PAC-Drive, and U-HID lighting and output controllers. (By Arzoo)
PluginLCD
GameEx plugin that supports LEDWiz, PACDrive, BetaBrite, BPP-440, CrystalFontz, PJRC, ProLite hardware devices. It also supports Speech and Sample event driven effects. (By HeadKaze)
UltraStik Plugin
GameEx plugin for UltraStik 360 (By HeadKaze)
GameEx Plugins
Other GameEx Plugins
JukePlugSys
Jukebox Plugin System. See Jukebox Plug-Ins (By Unclet / Space Fractal / HeadKaze / Loadman)
Screen Savers
EmuSaver
Emulator Screensaver (By Howard Casto)
Mame Screensaver
Mame Screensaver (By Tom Speirs)
Random Mame Launcher
Randomly loads a new random MAME ROM for a specific amount of time (which you specify). Useful for arcade cabinets in which you want to randomize your game selection (e.g. have your games run a new random game for each different day). (By emb)
TB_ScreenSaver
TB_ScreenSaver is a Windows 2000/XP/Vista picture screen saver that displays pictures from a user-specified directory using one of nine formats. TB_ScreenSaver supports MAME by displaying MAME pictures then running the games. (By Kenneth W. McKirahan)
File Renamers
Oscar's File Renamer
Program to rename files using text editor type functions like Quick find, Replace, multiple Undo/Redo, Macros and of course normal editing. (By Oscar)
Bulk Rename Utility
Bulk Rename Utility is a utility which allows you to easily rename files and directories, based upon extemely flexible criteria. Add date-stamps, replace numbers, insert strings, convert case, add auto-numbers, process folders and subfolders....plus loads more! (By Jim Willsher)
Flash Renamer
Batch rename multiple files in a single click! A great time saving tool for managing your file collections, such as digital photos, mp3 music, movies and so forth. (By Dan)
Generic Artwork Renamer
A neat little program written by Howard_Casto (author of the Dragon King Front End) that allows you to easily rename files. A great program that will attempt to rename screenshots by cross-referencing with a given list of game filenames. (By Howard Casto)
FuzzyRename
An easy to use tool to help rename png/avi files to match your rom/zip files. Uses fuzzy logic to match names that are similar.(By NOP)
FatMatch
Image renamer. Immediate Progress Report on Fuzzy Matching, folder selection as opposed to list copy-pasting, treeview of results for easier match picking, software-controlled file renaming. (By Fatone85)
Skinny Match
Image renamer. Run Skinny Match, and you will be asked to browse to your rom, and art paths. You can use the 'Add Path' button to add additional art paths. The first art path that you enter will be the primary path that is used for matching. Any additional paths will have the art renamed, if the names in the secondary paths match the names in the primary path. (By Tempest)
Run Files as a Service
XYNTService
This utility lets you start and stop any program as if it were a Windows System Service. This is especially useful for starting programs in the background even if you have Windows set up to boot directly into your Frontend. (By Xiangyang Liu)
RunAsSvc
Another program for running apps as a service. (By Dieter Schmeer)
Emulator Wrappers
BYOAC Wrappers
Wrappers are small utilities used to "wrap" an emulator to automate it's launching and exiting. (By BYOAC Community)
Visual Pinball Wrapper
Wrapper for launching Visual Pinball (By Howard Casto)
Chankast Launch
This is a wrapper for the Dreamcast emulator Chankast. It works with all versions of Chankast, even those that are not designed for full screen mode. It is also written in C++ and is only 72k in size. (By Headkaze)
WinUAE Loader
WinUAE Loader is a WinUAE launcher for arcade cabinets. It supports GameBase Amiga, SPS and WHDLoad game sets and allows you to remap input to suit arcade controls. (By Headkaze)
Misc Tools
Daemon Tools
Program to create virtual drives (useful for mounting CD images)
Mame Compiler 64
FE to help compiling Mame and applying diff patches. Supports Mame 32/64 and MameUI 32/64. (By HeadKaze)
Hiscore Diff's
Hiscore diff's for all MAME versions without hiscore support (107u2 - current). (By MKChamp)
Instant Sheller
Hide Windows boot up screen, cursors, desktop and boot straight into a Front End. See Hiding Windows (By Tom Speirs)
Quick Sheller
Hide Windows boot up screen, cursors, desktop and boot straight into a Front End. See Hiding Windows (By Lave Laar)
Mame Interop SDK
The MameInterop SDK is a collection of source code projects to help with writing applications that communicate with Mame using it's built in output system developed by the MAME Team. (By MAME Team / HeadKaze / Howard Casto)
Mame Hooker
Program to control hardware through the COM/Parallel ports including LEDWiz, PACDrive, IO Warrior and Keyboard LED's using a scripting engine. It can communicate with Mame and other software as well as display artwork on a secondary monitor. (By Howard Casto)
WMPFull
Play video files using Windows Media Player in fullscreen. Will exit when ESC is pressed or the video has finished playing. (By HeadKaze)
Web Cam Snap
Attach a webcam to your cab and take snaps or video's of visitors. Play them back later in your Front End. (By HeadKaze)
Scanner
A hard disk usage visualization tool. An extended pie chart displays all major files and folders. (By Steffen Gerlach)
Joystick Utilities
Several useful joystick utilities are located at this site including Clear Calibration Utility (clear the calibration of your joysticks), DXTweak 2 (Tweak various settings such as deadzone), JoyIDs Utility (change the Id's of your joysticks), Poswdm Utility (Allows you to see axis and button data).
SetDMD
SetDMD is a tool, mainly for virtual pinball cabinet owners, that allows you to easily set your DMD position as well as some other parameters in the DMD for all installed ROMs in the system at once. (By BigBoss)
  • Like 6
