5th February 2006
- GameEx 5.50
  • Enhancements
    • A new theme with two
      variations is now included - "MCE
      Glossy" and "Default New". Many
      thanks to Alan R. The MCE Glossy theme really
      is something special and worth the download.
    • There is a new theme
      picker available right within GameEx to allow
      you to preview themes and change on the fly.
    • GameEx now plays a
      "Please Wait" animation when its
      performing tasks that are going to take
      several seconds.
    • Its now possible to continue
      playing music after launching an emulator, and
      its possible to skip go to previous and stop
      the Jukebox music while running an emulator.
    • GameExtender Viewer
      application has been optimized to run faster.
    Fixes
    • Fixes attract mode when
      its set just to play videos
    • GameExtender Viewer now
      resizes correctly when the resolution is
      changed
    • Fixes Jukebox not
      disabled when installing for MCE or Games only
      usage.
    [*]Changes
    • Replaced the rectangular
      blue GameEx logo in all themes.
Nice update!
How do I set custom text for the "Theme picker" field? I haven't looked at the GameEx.ini file, just the configuration tool.
Edit: Found in GameEx.ini:
themepickerlist=
themepickerstart=
and when I did edit them I lost a bunch of features on my start page. :( Weird.
more testing on the way.
Edit 2: I have now found the "Theme Picker" field in Text/Language. I didn't see it at first as it was blank by default. Weird. But now I have everything under control again.
It seems like if you insert " " in the fields that you want to be left blank (I don't like the "List" text to show with my theme for example and then edit the ini file manually, the " " are nullified.
Emph
The loading screen or little window that pops up saying loading appears in strange places in window mode. Might need to make it open centre to parent or something.
I know ;) Just fixed it a few minutes ago. Also added Vsync to it.
Thanks.
