thurmansevolution Posted June 13, 2012 Share Posted June 13, 2012 Hello and good day to all!I'm having a bit of some trouble involving album art - I'm using WMP to tag the audio, and have updated all the album art within it. I've also got META data using GameEx. (when I tried to figure out how to fix this issue) For some reason, the playlist will play correctly, but the album art never changes - always stays on one album.I've tried deleting all the album art in the GameEx foulder, and re downloaded everything, but it did basically the same - showed a different album cover instead, but does not change when a new song starts playing.Any help will be greatly appricated, and thank you in advance for all your hard work so far!! Link to comment Share on other sites More sharing options...
Tom Speirs Posted June 13, 2012 Share Posted June 13, 2012 GameEx looks for folder.jpg first in the same folder that the track is in. You will have this problem if all your music is in one folder and folder.jpg exists. You could try deleting folder.jpg. It might be a hidden file. Link to comment Share on other sites More sharing options...
thurmansevolution Posted June 14, 2012 Author Share Posted June 14, 2012 (edited) Thanks a million Tom!! You da man! Edited March 2, 2013 by nullPointer This topic has been marked as RESOLVED and is now closed. Please begin a new thread if you are experiencing any similar issues. Link to comment Share on other sites More sharing options...
