After the latest update my menu font isn't working anymore.
Here's what the font looks like now, and what it should look like.
You may have already done it but have you checked the font options in theme editor, Bold or font style? Maybe you could change it completely then test it, then revert back to the one you were using?
i would like to know, how you even get that cool style with your font ;) . is this a registered feature or what?
as far as i know, you can only use 2 sizes with 2 different fonts. i dont understand how you achieved that cool effect (i know how you maked the shadow for the depth ;) ).
try the kaceyrayclare advice... :)
Hi u-man,
The option you are looking for is 'Static Start Page List'. You can find the setting in the Theme Editor under Edit > Options > Settings, or in your theme.ini file StaticStartPageList=True
Hi u-man,
mucho gracias :)
Too bad we can't use an image for the name or even have the same display for our individual game names like that then we could have a Hyperspin wheel display for our games/emulators.
