Great theme Krakerman, and I think I'm nearly there with it.........
For most of my emulators, they load up fine and the background is perfect for where you have set the video previews to play etc - I didn't have to set the Custom Background. For a few of the systems, however, there was no background, so I manually set the Custom background so that it picked up the right background for the emulator. Problem though is that the video previews etc are not in the right part of the screen. I've attached a pic of my Nintendo Entertainment System screen so you know what I mean. Have I missed a step when setting it up?
I also noticed that the Emulator menu is not in the right part of the screen now (another pic attached), but I'm sure it was before? Again, is there a setting I've missed?
post-7352-0-83516700-1338720399_thumb.jp
post-7352-0-25356200-1338720573_thumb.jp
Hmmm Load the theme into the theme editor and goto the options/settings and make sure custom emulator layouts and custom module layouts are checked.
All almost forgot by looking at your snaps you need to disable a few features like:
- Hide Change View
- There is also another one but I can't think of it right at the moment. So the By Manufacturer, By Date doesn't display.
These boxes were already checked.
- Hide Change View
Done - but problem remains. Latest log file follows -
10:54:26.2 9/06/2012: Opening Configuration File
10:54:26.2 9/06/2012: GameEx: Version 12.62: Starting Log
10:54:26.2 9/06/2012: Operating System Platform: Win32NT
10:54:26.2 9/06/2012: Operating System Name: Windows XP
10:54:26.2 9/06/2012: Operating System Version: 5.1.2600
10:54:26.2 9/06/2012: Intel® Core™2 CPU 6300 @ 1.86GHz, 1007MB
10:54:26.2 9/06/2012: 1.86Ghz - 2 Cores or CPU's
10:54:26.2 9/06/2012: Running Randomize()
10:54:26.3 9/06/2012: Loading PlugIns
10:54:26.3 9/06/2012: Checking for applications to Launch On Startup
10:54:26.3 9/06/2012: Running Misc startup tasks
10:54:26.3 9/06/2012: Setting Menu types
10:54:26.3 9/06/2012: Getting Configuration Values
10:54:26.3 9/06/2012: Using Theme: Retro Arcade HD
10:54:26.3 9/06/2012: Checking for alternate Image Directory for Theme: Retro Arcade HD
10:54:26.3 9/06/2012: Launching HideOS.exe
10:54:26.3 9/06/2012: Initialising Video/MNG DLL's
10:54:26.3 9/06/2012: GameEx will check for media insertion (may affect performance)
10:54:26.3 9/06/2012: Hiding Taskbar
10:54:26.3 9/06/2012: Is Media Center running?
10:54:26.3 9/06/2012: Checking/Creating LCD Registry values
10:54:26.3 9/06/2012: Check Media Center Exit/Start Mode
10:54:26.3 9/06/2012: Media Center Mode 2
10:54:26.3 9/06/2012: Video previews on. Warning: Only recommended on modern systems
10:54:26.3 9/06/2012: Custom Keyboard Input enabled: Getting custom codes
10:54:26.3 9/06/2012: Snap Delay set to: 5
10:54:26.3 9/06/2012: Get other settings
10:54:26.3 9/06/2012: Desktop set to Hide ICONS and set Background to Black
10:54:26.3 9/06/2012: SlikStik support enabled
10:54:26.3 9/06/2012: Using DirectInput for keyboard input
10:54:26.3 9/06/2012: Start work for Form
10:54:26.3 9/06/2012: Getting Original Screen Size
10:54:26.3 9/06/2012: Compacting Database
10:54:26.7 9/06/2012: Opening Database Connection
10:54:26.7 9/06/2012: Initializing Component
10:54:26.8 9/06/2012: MAME Path is: C:\Emulators\Mame32\Mame_133
10:54:26.8 9/06/2012: daphne Path is: C:\Emulators\Daphne
10:54:26.8 9/06/2012: daphne EXE file is: Daphne.exe
10:54:26.8 9/06/2012: Use daphne on. Daphne.exe will launch games
10:54:26.8 9/06/2012: ZiNc Path is: C:\Emulators\Zinc
10:54:26.8 9/06/2012: ZiNc EXE file is: zinc.exe
10:54:26.8 9/06/2012: Use ZiNc on. zinc.exe will launch PSX games
10:54:26.8 9/06/2012: MAME EXE file is: mame.exe
10:54:26.8 9/06/2012: ROM Path is: C:\Emulators\Mame32\Mame_133\roms
10:54:26.8 9/06/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
10:54:26.8 9/06/2012: controls.ini is located at: C:\GameEx\data\controls.ini
10:54:26.8 9/06/2012: History.dat is located at: C:\GameEx\DATA\history.dat
10:54:26.8 9/06/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
10:54:26.8 9/06/2012: command.dat is located at: C:\GameEx\DATA\command.dat
10:54:26.8 9/06/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
10:54:26.8 9/06/2012: Loading Controls.ini map file
10:54:26.8 9/06/2012: Snap Path is: C:\Emulators\Mame32\Mame_133\snap
10:54:26.8 9/06/2012: Background Snap Path: Not Found
10:54:26.8 9/06/2012: AVI Snap Path is: C:\Emulators\Mame32\Mame_133\Videos
10:54:26.8 9/06/2012: Flyer Path is: C:\Emulators\Mame32\Mame_133\flyers
10:54:26.8 9/06/2012: Cabinet Path is: C:\Emulators\Mame32\Mame_133\cabinets
10:54:26.8 9/06/2012: Cabinet 3D Path: Not Found
10:54:26.8 9/06/2012: Title Path is: C:\Emulators\Mame32\Mame_133 itles
10:54:26.8 9/06/2012: PCB Path is: C:\Emulators\Mame32\Mame_133\pcb
10:54:26.8 9/06/2012: Artwork Preview Path is: C:\Emulators\Mame32\Mame_133\artwork
10:54:26.8 9/06/2012: Panel Path is: C:\Emulators\Mame32\Mame_133\cpanel
10:54:26.8 9/06/2012: Manual Path: Not Found
10:54:26.8 9/06/2012: Icon Path is: C:\Emulators\Mame32\Mame_133\icons
10:54:26.8 9/06/2012: Marquee Path is: C:\Emulators\Mame32\Mame_133\marquees
10:54:26.8 9/06/2012: Applying Language/Text
10:54:26.8 9/06/2012: Text/Language: English
10:54:26.9 9/06/2012: Loading Custom Emulators
10:54:26.9 9/06/2012: Loading Emulator 1: Super Nintendo Entertainment System
10:54:26.9 9/06/2012: Loading Emulator 2: Atari Jaguar
10:54:26.9 9/06/2012: Loading Emulator 4: Sega Master System
10:54:26.9 9/06/2012: Loading Emulator 6: Atari Lynx
10:54:26.9 9/06/2012: Loading Emulator 7: Sega Genesis
10:54:26.9 9/06/2012: Loading Emulator 9: Sega Game Gear
10:54:26.9 9/06/2012: Loading Emulator 10: Nintendo Entertainment System
10:54:26.9 9/06/2012: Loading Emulator 13: Sega SG 1000
10:54:26.9 9/06/2012: Loading Emulator 15: Nintendo N64
10:54:26.9 9/06/2012: Using Version 3 Themes Animations
10:54:26.9 9/06/2012: Retrieving resolution setting
10:54:26.9 9/06/2012: Error Loading Font: Boulder
10:54:26.9 9/06/2012: Using General Font: Arial
10:54:26.9 9/06/2012: Using Title Font: Arial
10:54:27.0 9/06/2012: Initialising Direct3D
10:54:27.1 9/06/2012: Applying GameEx is Loading Image
10:54:27.1 9/06/2012: Setting Resolution to 1280x1024 32 bit color
10:54:27.1 9/06/2012: Creating Surfaces
10:54:27.8 9/06/2012: Creating Primary Surface - Full Screen Mode
10:54:27.8 9/06/2012: Creating Back Buffer
10:54:27.8 9/06/2012: Version 2 Theme being used. Loading.
10:54:27.8 9/06/2012: Loading Button Data
10:54:27.8 9/06/2012: Loading Font Data
10:54:27.8 9/06/2012: Loading Layout Data
10:54:27.8 9/06/2012: Loading Taskbar Data
10:54:27.8 9/06/2012: Loading graphic Surfaces
10:54:27.8 9/06/2012: Display is running at: 1280x1024 32bit color, 60hz
10:54:27.8 9/06/2012: Adapter: Intel® Q965/Q963 Express Chipset Family
10:54:27.8 9/06/2012: Max texture size: 2048x2048
10:54:27.8 9/06/2012: Available texture memory: 202MB
10:54:27.8 9/06/2012: Initialising Bass Audio Library
10:54:27.9 9/06/2012: Creating Surfaces Misc and Dialogs
10:54:28.0 9/06/2012: Creating Surfaces Volume
10:54:28.0 9/06/2012: Creating Surfaces Arrows
10:54:28.0 9/06/2012: Creating Surfaces GameEXlogo Text
10:54:28.0 9/06/2012: Creating Surfaces Toolbar
10:54:28.0 9/06/2012: Creating Surfaces Toolbar Controls
10:54:28.0 9/06/2012: Creating Surfaces Backgrounds
10:54:28.0 9/06/2012: Creating Surfaces GameEx Logo
10:54:28.1 9/06/2012: Creating Surface Unselected
10:54:28.1 9/06/2012: Creating Surfaces Snaps
10:54:28.1 9/06/2012: Creating Surfaces Menu and List Bars
10:54:28.2 9/06/2012: Creating Fonts
10:54:28.2 9/06/2012: Creating Game Font
10:54:28.3 9/06/2012: Creating Game Font Faded
10:54:28.4 9/06/2012: Creating Title Font
10:54:28.4 9/06/2012: Restoring Title Font From Cache
10:54:28.5 9/06/2012: Creating Font Black
10:54:28.6 9/06/2012: Creating Font Black Small
10:54:28.7 9/06/2012: Fonts Created Succesfully
10:54:28.8 9/06/2012: 8MB Video Memory Used
10:54:29.7 9/06/2012: Attempting to load game list
10:54:29.8 9/06/2012: MAME CMD options: -nowindow -hwstretch -joy -skip_gameinfo
10:54:29.9 9/06/2012: Creating DirectSound Device
10:54:29.9 9/06/2012: Trying: Primary Sound Driver
10:54:29.9 9/06/2012: Loading Sound Files
10:54:30.0 9/06/2012: DirectSound Device Created Successfully
10:54:30.0 9/06/2012: Initialising DirectInput for Gamepad support
10:54:30.0 9/06/2012: Unable to create a joystick device
10:54:30.0 9/06/2012: Initialising DirectInput for Keyboard support
10:54:30.0 9/06/2012: Loading Start Page
10:54:30.1 9/06/2012: Initializing MCE Remote
10:54:30.1 9/06/2012: Playing intro sound file
10:54:30.1 9/06/2012: Initialization OK! Starting GameEx!
10:54:30.1 9/06/2012: Testing Main Loop Once: Processing Frame
10:54:30.4 9/06/2012: Testing Main Loop Once: Main Loop ran successfully
10:54:42.7 9/06/2012: Saving Settings
10:54:42.7 9/06/2012: Running: cmd.exe /c C: GameExConfig.exe
10:54:42.9 9/06/2012: Shutting down display
10:57:20.3 9/06/2012: GameEx configuration updated, reinitialising
10:57:20.3 9/06/2012: Reloading Configuration file
10:57:20.4 9/06/2012: Getting Configuration Values
10:57:20.4 9/06/2012: Using Theme: Retro Arcade HD
10:57:20.4 9/06/2012: Checking for alternate Image Directory for Theme: Retro Arcade HD
10:57:20.4 9/06/2012: Launching HideOS.exe
10:57:20.4 9/06/2012: Initialising Video/MNG DLL's
10:57:20.4 9/06/2012: GameEx will check for media insertion (may affect performance)
10:57:20.4 9/06/2012: Hiding Taskbar
10:57:20.4 9/06/2012: Is Media Center running?
10:57:20.4 9/06/2012: Checking/Creating LCD Registry values
10:57:20.4 9/06/2012: Check Media Center Exit/Start Mode
10:57:20.4 9/06/2012: Media Center Mode 2
10:57:20.4 9/06/2012: Video previews on. Warning: Only recommended on modern systems
10:57:20.4 9/06/2012: Custom Keyboard Input enabled: Getting custom codes
10:57:20.4 9/06/2012: Snap Delay set to: 5
10:57:20.4 9/06/2012: Get other settings
10:57:20.4 9/06/2012: SlikStik support enabled
10:57:20.4 9/06/2012: Using DirectInput for keyboard input
10:57:20.4 9/06/2012: Opening Database Connection
10:57:20.4 9/06/2012: MAME Path is: C:\Emulators\Mame32\Mame_133
10:57:20.4 9/06/2012: daphne Path is: C:\Emulators\Daphne
10:57:20.4 9/06/2012: daphne EXE file is: Daphne.exe
10:57:20.4 9/06/2012: Use daphne on. Daphne.exe will launch games
10:57:20.4 9/06/2012: ZiNc Path is: C:\Emulators\Zinc
10:57:20.4 9/06/2012: ZiNc EXE file is: zinc.exe
10:57:20.4 9/06/2012: Use ZiNc on. zinc.exe will launch PSX games
10:57:20.4 9/06/2012: MAME EXE file is: mame.exe
10:57:20.4 9/06/2012: ROM Path is: C:\Emulators\Mame32\Mame_133\roms
10:57:20.4 9/06/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
10:57:20.4 9/06/2012: controls.ini is located at: C:\GameEx\data\controls.ini
10:57:20.4 9/06/2012: History.dat is located at: C:\GameEx\DATA\history.dat
10:57:20.4 9/06/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
10:57:20.4 9/06/2012: command.dat is located at: C:\GameEx\DATA\command.dat
10:57:20.4 9/06/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
10:57:20.4 9/06/2012: Snap Path is: C:\Emulators\Mame32\Mame_133\snap
10:57:20.4 9/06/2012: Background Snap Path: Not Found
10:57:20.4 9/06/2012: AVI Snap Path is: C:\Emulators\Mame32\Mame_133\Videos
10:57:20.4 9/06/2012: Flyer Path is: C:\Emulators\Mame32\Mame_133\flyers
10:57:20.4 9/06/2012: Cabinet Path is: C:\Emulators\Mame32\Mame_133\cabinets
10:57:20.4 9/06/2012: Cabinet 3D Path: Not Found
10:57:20.4 9/06/2012: Title Path is: C:\Emulators\Mame32\Mame_133 itles
10:57:20.4 9/06/2012: PCB Path is: C:\Emulators\Mame32\Mame_133\pcb
10:57:20.4 9/06/2012: Artwork Preview Path is: C:\Emulators\Mame32\Mame_133\artwork
10:57:20.4 9/06/2012: Panel Path is: C:\Emulators\Mame32\Mame_133\cpanel
10:57:20.4 9/06/2012: Manual Path: Not Found
10:57:20.4 9/06/2012: Icon Path is: C:\Emulators\Mame32\Mame_133\icons
10:57:20.4 9/06/2012: Marquee Path is: C:\Emulators\Mame32\Mame_133\marquees
10:57:20.4 9/06/2012: Applying Language/Text
10:57:20.4 9/06/2012: Text/Language: English
10:57:20.5 9/06/2012: Loading Custom Emulators
10:57:20.5 9/06/2012: Loading Emulator 1: Super Nintendo Entertainment System
10:57:20.5 9/06/2012: Loading Emulator 2: Atari Jaguar
10:57:20.5 9/06/2012: Loading Emulator 4: Sega Master System
10:57:20.5 9/06/2012: Loading Emulator 6: Atari Lynx
10:57:20.5 9/06/2012: Loading Emulator 7: Sega Genesis
10:57:20.5 9/06/2012: Loading Emulator 9: Sega Game Gear
10:57:20.5 9/06/2012: Loading Emulator 10: Nintendo Entertainment System
10:57:20.5 9/06/2012: Loading Emulator 13: Sega SG 1000
10:57:20.5 9/06/2012: Loading Emulator 15: Nintendo N64
10:57:20.5 9/06/2012: Using Version 3 Themes Animations
10:57:20.5 9/06/2012: Retrieving resolution setting
10:57:20.5 9/06/2012: Error Loading Font: Boulder
10:57:20.5 9/06/2012: Using General Font: Arial
10:57:20.5 9/06/2012: Using Title Font: Arial
10:57:20.6 9/06/2012: Initialising Direct3D
10:57:20.6 9/06/2012: Applying GameEx is Loading Image
10:57:20.6 9/06/2012: Setting Resolution to 1280x1024 32 bit color
10:57:20.6 9/06/2012: Creating Surfaces
10:57:20.6 9/06/2012: Creating Primary Surface - Full Screen Mode
10:57:20.6 9/06/2012: Creating Back Buffer
10:57:20.6 9/06/2012: Version 2 Theme being used. Loading.
10:57:20.6 9/06/2012: Loading Button Data
10:57:20.6 9/06/2012: Loading Font Data
10:57:20.6 9/06/2012: Loading Layout Data
10:57:20.6 9/06/2012: Loading Taskbar Data
10:57:20.6 9/06/2012: Loading graphic Surfaces
10:57:20.6 9/06/2012: Display is running at: 1280x1024 32bit color, 60hz
10:57:20.6 9/06/2012: Adapter: Intel® Q965/Q963 Express Chipset Family
10:57:20.6 9/06/2012: Max texture size: 2048x2048
10:57:20.6 9/06/2012: Available texture memory: 202MB
10:57:20.6 9/06/2012: Initialising Bass Audio Library
10:57:20.7 9/06/2012: Creating Surfaces Misc and Dialogs
10:57:20.7 9/06/2012: Creating Surfaces Volume
10:57:20.7 9/06/2012: Creating Surfaces Arrows
10:57:20.7 9/06/2012: Creating Surfaces GameEXlogo Text
10:57:20.7 9/06/2012: Creating Surfaces Toolbar
10:57:20.7 9/06/2012: Creating Surfaces Toolbar Controls
10:57:20.7 9/06/2012: Creating Surfaces Backgrounds
10:57:20.8 9/06/2012: Creating Surfaces GameEx Logo
10:57:20.8 9/06/2012: Creating Surface Unselected
10:57:20.8 9/06/2012: Creating Surfaces Snaps
10:57:20.8 9/06/2012: Creating Surfaces Menu and List Bars
10:57:20.9 9/06/2012: Creating Fonts
10:57:20.9 9/06/2012: Creating Game Font
10:57:20.9 9/06/2012: Creating Game Font Faded
10:57:21.0 9/06/2012: Creating Title Font
10:57:21.0 9/06/2012: Restoring Title Font From Cache
10:57:21.2 9/06/2012: Creating Font Black
10:57:21.3 9/06/2012: Creating Font Black Small
10:57:21.4 9/06/2012: Fonts Created Succesfully
10:57:21.4 9/06/2012: 8MB Video Memory Used
10:57:22.2 9/06/2012: Attempting to load game list
10:57:22.3 9/06/2012: MAME CMD options: -nowindow -hwstretch -joy -skip_gameinfo
10:57:22.4 9/06/2012: Loading Start Page
10:57:22.4 9/06/2012: Initializing MCE Remote
10:57:22.4 9/06/2012: Testing Main Loop Once: Main Loop ran successfully
10:57:36.0 9/06/2012: Validating: Emulator_1: Custom Background: theme_background_nintendo snes.png
10:57:36.0 9/06/2012: Validating: Emulator_1: Snap Path: C:\Emulators\Nintendo\Super Nintendo Entertainment System\Video
10:57:36.0 9/06/2012: Validating: Emulator_1: Database: [Console] Nintendo SNES
10:57:36.1 9/06/2012: Validating: Emulator_1: Title Snap Path: C:\Emulators\Nintendo\Super Nintendo Entertainment System\Titles
10:57:36.1 9/06/2012: Validating: Emulator_1: Box Art Path: C:\Emulators\Nintendo\Super Nintendo Entertainment System\Box Art
10:57:36.1 9/06/2012: Validating: Emulator_1: Cart Art Path: C:\Emulators\Nintendo\Super Nintendo Entertainment System\Cartridge Art
10:57:36.1 9/06/2012: Validating: Emulator_2: Custom Background: theme_background_atari jaguar.png
10:57:36.1 9/06/2012: Validating: Emulator_2: Snap Path: C:\Emulators\Atari\Jaguar\Video
10:57:36.1 9/06/2012: Validating: Emulator_2: Custom Art Path 1: C:\Emulators\Atari\Jaguar
10:57:36.1 9/06/2012: Validating: Emulator_2: Database: [Console] Atari Jaguar
10:57:36.2 9/06/2012: Validating: Emulator_2: Title Snap Path: C:\Emulators\Atari\Jaguar\Titles
10:57:36.2 9/06/2012: Validating: Emulator_2: Box Art Path: C:\Emulators\Atari\Jaguar\Box Art
10:57:36.2 9/06/2012: Validating: Emulator_4: Custom Background: theme_background_sega master system.png
10:57:36.2 9/06/2012: Validating: Emulator_4: Snap Path: C:\Emulators\Sega\SMS\Video
10:57:36.2 9/06/2012: Validating: Emulator_4: Custom Art Path 1: C:\Emulators\Sega\SMS
10:57:36.2 9/06/2012: Validating: Emulator_4: Database: [Console] Sega Master System
10:57:36.2 9/06/2012: Validating: Emulator_4: Title Snap Path: C:\Emulators\Sega\SMS\Titles
10:57:36.2 9/06/2012: Validating: Emulator_4: Box Art Path: C:\Emulators\Sega\SMS\Box Art
10:57:36.2 9/06/2012: Validating: Emulator_6: Custom Background: theme_background_atari lynx.png
10:57:36.2 9/06/2012: Validating: Emulator_6: Snap Path: C:\Emulators\Atari\Lynx\Video
10:57:36.2 9/06/2012: Validating: Emulator_6: Custom Art Path 1: C:\Emulators\Atari\Lynx
10:57:36.2 9/06/2012: Validating: Emulator_6: Database: [Handheld] Atari Lynx
10:57:36.2 9/06/2012: Validating: Emulator_6: Title Snap Path: C:\Emulators\Atari\Lynx\Titles
10:57:36.2 9/06/2012: Validating: Emulator_7: Custom Background: theme_background_sega genesis.png
10:57:36.2 9/06/2012: Validating: Emulator_7: Snap Path: C:\Emulators\Sega\Genesis\Video
10:57:36.2 9/06/2012: Validating: Emulator_7: Custom Art Path 1: C:\Emulators\Sega\Genesis\Themes\Default
10:57:36.2 9/06/2012: Validating: Emulator_7: Database: [Console] Sega Genesis
10:57:36.2 9/06/2012: Validating: Emulator_7: Title Snap Path: C:\Emulators\Sega\Genesis\Titles
10:57:36.2 9/06/2012: Validating: Emulator_7: Box Art Path: C:\Emulators\Sega\Genesis\Box Art
10:57:36.2 9/06/2012: Validating: Emulator_9: Custom Background: theme_background_sega game gear.png
10:57:36.2 9/06/2012: Validating: Emulator_9: Snap Path: C:\Emulators\Sega\Game Gear\Video
10:57:36.2 9/06/2012: Validating: Emulator_9: Custom Art Path 1: C:\Emulators\Sega\Game Gear
10:57:36.2 9/06/2012: Validating: Emulator_9: Database: [Console] Sega CD
10:57:36.2 9/06/2012: Validating: Emulator_9: Title Snap Path: C:\Emulators\Sega\Game Gear\Titles
10:57:36.2 9/06/2012: Validating: Emulator_9: Box Art Path: C:\Emulators\Sega\Game Gear\Box Art
10:57:36.2 9/06/2012: Validating: Emulator_10: Custom Background: theme_background_nintendo nes.png
10:57:36.2 9/06/2012: Validating: Emulator_10: Snap Path: C:\Emulators\Nintendo\Nintendo Entertainment System\Video
10:57:36.2 9/06/2012: Validating: Emulator_10: Custom Art Path 1: C:\Emulators\Nintendo\Nintendo Entertainment System\Themes
10:57:36.2 9/06/2012: Validating: Emulator_10: Database: [Console] Nintendo NES
10:57:36.2 9/06/2012: Validating: Emulator_10: Title Snap Path: C:\Emulators\Nintendo\Nintendo Entertainment System\Titles
10:57:36.2 9/06/2012: Validating: Emulator_10: Box Art Path: C:\Emulators\Nintendo\Nintendo Entertainment System\Box Art
10:57:36.2 9/06/2012: Validating: Emulator_10: Cart Art Path: C:\Emulators\Nintendo\Nintendo Entertainment System\Cartridges
10:57:36.2 9/06/2012: Validating: Emulator_13: Custom Background: theme_background_sega sg-1000.png
10:57:36.2 9/06/2012: Validating: Emulator_13: Snap Path: C:\Emulators\Sega\SG1000\Video
10:57:36.2 9/06/2012: Validating: Emulator_13: Custom Art Path 1: C:\Emulators\Sega\SG1000
10:57:36.2 9/06/2012: Validating: Emulator_13: Database: [Console] Sega CD
10:57:36.2 9/06/2012: Validating: Emulator_13: Title Snap Path: C:\Emulators\Sega\SG1000\Images\Titles
10:57:36.2 9/06/2012: Validating: Emulator_13: Box Art Path: C:\Emulators\Sega\SG1000\Images\Box Art
10:57:36.2 9/06/2012: Validating: Emulator_15: Custom Background: theme_background_nintendo 64.png
10:57:36.2 9/06/2012: Validating: Emulator_15: Snap Path: C:\Emulators\Nintendo\64\Video
10:57:36.2 9/06/2012: Validating: Emulator_15: Custom Art Path 1: C:\Emulators\Nintendo\64
10:57:36.2 9/06/2012: Validating: Emulator_15: Database: [Console] Nintendo N64
10:57:36.2 9/06/2012: Validating: Emulator_15: Title Snap Path: C:\Emulators\Nintendo\64\Titles
10:57:36.2 9/06/2012: Validating: Emulator_15: Box Art Path: C:\Emulators\Nintendo\64\Box Art
10:57:36.2 9/06/2012: Validating: Emulator_15: Cart Art Path: C:\Emulators\Nintendo\64\Cartridges
10:57:36.6 9/06/2012: Restoring Emulator from Cache: 10
10:57:36.7 9/06/2012: DBCache Diff: 13/11/2009 11:23:11 AM - 13/11/2009 11:23:11 AM
10:57:37.0 9/06/2012: Not Restoring Emulator Database From Cache: 10
10:58:20.7 9/06/2012: Exiting GameEx!
10:58:20.7 9/06/2012: Disposing all videos
10:58:20.8 9/06/2012: Deleting temporary Karaoke videos
10:58:20.8 9/06/2012: Disposing Image List
10:58:20.8 9/06/2012: Disposing Fonts
10:58:20.8 9/06/2012: Disposing Surfaces
10:58:20.8 9/06/2012: Saving Settings
10:58:20.8 9/06/2012: Shutting down Bass
10:58:20.8 9/06/2012: Closing HideOS.exe
10:58:21.1 9/06/2012: Disposing Plugins
10:58:21.1 9/06/2012: Closing database connection
10:58:21.1 9/06/2012: Checking for applications to Launch On Exit
10:58:21.1 9/06/2012: Bye
Looks like you are getting an error with the Boulder font. Did you install the font that I included with the zip?
I have the same problem with some of the emulator screens having no background and the layout being wrong. I noticed that some of the names of the ini files differ to what my emulator entries are named. Such as Atomiswave - where mine is named Sammy Atomiswave. So by renaming it to Sammy Atomiswave, this corrected the layout issue. I still needed to select a background for it though.
Thanks Bigby - so when you say 'different to what your emulator entries are named', do you refer to the name of the emulator folders? In other words, I need to match the emaultor folder names to the .ini names in the theme?
I'm away for a few weeks niow, but looking forward to giving this a try when I get back home!
  • 4 weeks later...
I can't for the life of me find where to download this font (and I can't see where the original zip file is)??
Can you clarify something here for me please Bigby - when you refer to your 'emulator entries' - are you referring to the folder names, or to the names that they've been assigned in the GameEx config menu? I've matched the .ini file names to my emulator folder names, but continue to have the problem with a few of them.
That shouldn't matter if you selected the page manually from "Advanced Emulator Setup".
But Bibgy is suggesting it does matter. I've selected the background manually in all of the Emulator SetUps, but it's still not lining up correctly on a few on the emulators. Bigby's post suggested that I needed to change the .ini files to match the 'emulator entries' - I'm just trying to clarify what he means by that.
I don't understand why they're in the INI to begin with is the problem, you should be able to choose it how you like without screwing with the INI in the emulator's config. You could simply delete those entries that specify files for specific emulators.
It's probably the emulator's TitleText property.
This was some time ago, but as I remember I opened the theme in the theme editor. In the "Templates" box, compare the names to what the layout ini's in the theme folder are. The ones in the theme editor are what GameEx expects them to be named.
Just to clarify, i don't mean to edit the contents of these layout ini's, just what they are named.
Ok, I now have all of the emulator backgrounds lining up! (woohoo!) - not entirely sure how I fixed it, I copied the backgrounds with a new name which matched the name I'd given the emulator in my GameEx settings, pointed to the new file, and it worked.
The only backgrounds that are now not lining up properly are my 'Emulators' menu, 'Most Played' and 'Last Played' - how do I tell GameEx to point to the files Krak has created for these menus?
I think I had those options disabled. I have been working on the new theme and I don't have retro arcade installed currently, but I think I might of had that off.
I find I have to manually change the position of the boxes myself sometimes. You do this by going to the second list on the left, selecting the page you are having troubles with, open the tree, and allow the layout to display in the main window. You'll see the positions of all the boxes, and just place them where you want them.
I think this happens because the theme either creates a new page for the emulator and uses a default layout... or your naming of your emulator might not match the provided pages in the theme.... if that makes sense.
I've had the same problem and cured it by just manually moving things around. For sanity of mind... I also find it's A LOT easier on your blood pressure to just use the same box positions in each background, but change the look of the background. You can then use the 'global' editiing method... which is when you first start the theme editor.
I hope I helped here and not confused you more... theme editing is not an exact science to me.
Thanks - that's helpful, I'll have a play with it and see how I go.
You are correct with the naming of the themes. I used my own naming of alot of the emulators so you do have to go in and make sure your emulator has the correct custom background for each emulator.
