Hey Team!
I have some questions about the dialog box.
In the picture above you can see the Dialog box image I'm using, but there is no text. This should be asking me if I want to update. If I remove the Dialog.png file I get the default dialog box.
Also the image doesn't seem to be lining up properly. Is there a certain dimension the image should be? Also is there a way to remove the transparency?
This also happens on the Update List in MAME.
If I blindly hit enter it shows the updating info...
If I had to guess it's size locked. Try resizing it to match the one in the default theme folder and see if it shows up?
