Hello,
Thx for this frontend that is the best I found (very easy to use for people like me that cant spend much time on his cab cuz woman/daughters .... you see what I mean ...)
I use this frontend with most configs that were done by users like Amiga Megadrive SNES .... but I cant' find one for Atari ST.
Could help me telling me what is the best AtariST emul to use with GameEx that accept command lines ?
Excuse me for my bad english, and thx for your help !
Hello,
my english is bad like you :)
The Atari ST is an amazing computer... and the emulator you can use with GameEx is STeem. It's a little bit hard to configure perfectly, but with 2-3 parameters it works correctly.
I don't have the config file here, but if it's too diificult, i send you the file tommorow.
Good luck ;)
Hello,
Good luck ;)
Thx very much for the answer Max : I'll try it this w-e .... maybe it's not to diferent than winUAE ....
if you have already a config file I'm interested : will make me save much time to make config files for each game !!!!
