Hi people, I'm new to the forum and I have a question about Nebula and NeoGeoCD.
After some playing around and looking on the internet I am unable to find the correct commandline to run Neo Geo CD games. The best I have been able to find is:
Nebula.exe neocd.
This loads nebula and runs the last used neogeocd game but it doesnt seem to allow a CUE file to be passed eg
Nebula.exe neocd [rom]
Can anyone guide me in how the neogeo cd commandline works please.
Thank you.
Hello and welcome to the forums! neocd is actually the name of the rom so there is no way of passing the iso image to command-line. The best solution would be to use daemon-tools lite to mount the image and then select the correct cd drive from nebula itself. If you have dt lite installed, then the command-line would be as follows:
nebula.exe neocd[-VIRTUALDRIVE-]
Other solutions would be to use a different emulator. NeoRAINE is recommended by NonMESS which is a great source for recommended emulators.
And if unsure about a command-line, it's best to import the settings for this emulator as the guess work has been done for you. ;)
