Hi. I've recently installed Game Ex. I've downloaded Nestopia/Virtuanes, SNex9x/ZSNES.
None of these emulators will actually run a game from within Game Ex. They all run games outside of it. Game Ex DOES find my rom directory, listing the games, but when I click play game, the Game Ex window disappears, the emulator doesn't start and eventually the Game Ex window returns.
An example of the log, when I click to play a game.
20:25:33.2 4/9/2012: Running: cmd.exe /c C: snes9x.exe -fullscreen "D:\Jolene\Games\Roms\Super Nintendo\Super Mario World (USA).sfc"
20:25:33.3 4/9/2012: Shutting down display
Here's the ini for SNES9x. All 4 of the emulators are set up the same, with the executable "[ROMPATH\[ROMFILE]" command.
20:23:07.6 4/9/2012: Opening Configuration File
20:23:07.7 4/9/2012: GameEx: Version 12.56: Starting Log
20:23:07.7 4/9/2012: Operating System Platform: Win32NT
20:23:07.7 4/9/2012: Operating System Name: Windows 7
20:23:07.7 4/9/2012: Operating System Version: 6.1.7601
20:23:07.7 4/9/2012: Aero running
20:23:07.7 4/9/2012: Initializing Vista/Windows 7 volume control
20:23:07.7 4/9/2012: AMD C-60 APU with Radeon HD Graphics, 3819MB
20:23:07.7 4/9/2012: 997Mhz - 2 Cores or CPU's
20:23:07.7 4/9/2012: Running Randomize()
20:23:07.7 4/9/2012: Loading PlugIns
20:23:07.8 4/9/2012: Checking for applications to Launch On Startup
20:23:07.8 4/9/2012: Running Misc startup tasks
20:23:07.8 4/9/2012: Setting Menu types
20:23:07.8 4/9/2012: Getting Configuration Values
20:23:07.8 4/9/2012: Using Theme: Default - RedEx - MCE1024x768
20:23:07.8 4/9/2012: Checking for alternate Image Directory for Theme: Default - RedEx - MCE1024x768
20:23:07.8 4/9/2012: Initialising Video/MNG DLL's
20:23:07.8 4/9/2012: GameEx will check for media insertion (may affect performance)
20:23:07.8 4/9/2012: Is Media Center running?
20:23:07.8 4/9/2012: Checking/Creating LCD Registry values
20:23:07.8 4/9/2012: Check Media Center Exit/Start Mode
20:23:07.8 4/9/2012: Media Center Mode 2
20:23:07.8 4/9/2012: Video previews on. Warning: Only recommended on modern systems
20:23:07.8 4/9/2012: Snap Delay set to: 2
20:23:07.8 4/9/2012: Get other settings
20:23:07.8 4/9/2012: Set: Find emulator artwork on best match basis
20:23:07.8 4/9/2012: Start work for Form
20:23:07.8 4/9/2012: Getting Original Screen Size
20:23:07.8 4/9/2012: Opening Database Connection
20:23:08.0 4/9/2012: Initializing Component
20:23:08.1 4/9/2012: MAME Path is: C:\Emulators\Mame32
20:23:08.1 4/9/2012: Cannot Find MAME Path: MAME Disabled
20:23:08.1 4/9/2012: Loading Controls.ini map file
20:23:08.2 4/9/2012: Applying Language/Text
20:23:08.2 4/9/2012: Text/Language: English
20:23:08.3 4/9/2012: Loading Custom Emulators
20:23:08.3 4/9/2012: Loading Emulator 1: [Console] Nintendo NES (Nestopia)
20:23:08.3 4/9/2012: Loading Emulator 2: [Console] Nintendo NES (VirtuaNES)
20:23:08.3 4/9/2012: Loading Emulator 3: [Console] Nintendo SNES (ZSNES)
20:23:08.3 4/9/2012: Loading Emulator 4: [Console] Nintendo SNES (Snes9x)
20:23:08.3 4/9/2012: Loading Emulator 5:
20:23:08.3 4/9/2012: Loading Emulator Group 1: Super Nintendo
20:23:08.3 4/9/2012: Could not load emulator group. Check emulators specified are valid.
20:23:08.4 4/9/2012: Using 2D Animations
20:23:08.4 4/9/2012: Retrieving resolution setting
20:23:08.4 4/9/2012: Using General Font: Trebuchet MS
20:23:08.4 4/9/2012: Using Title Font: Trebuchet MS
20:23:08.4 4/9/2012: GameEx will try to reduce CPU usage
20:23:08.4 4/9/2012: Initialising Direct3D
20:23:08.7 4/9/2012: Creating Surfaces
20:23:09.1 4/9/2012: Creating Primary Surface - Windowed Mode
20:23:09.1 4/9/2012: Creating Back Buffer
20:23:09.2 4/9/2012: Loading graphic Surfaces
20:23:09.2 4/9/2012: Display is running at: 1366x768 32bit color, 60hz
20:23:09.2 4/9/2012: Adapter: AMD Radeon HD 6290 Graphics
20:23:09.2 4/9/2012: Max texture size: 16384x16384
20:23:09.2 4/9/2012: Available texture memory: 1899MB
20:23:09.3 4/9/2012: Initialising Bass Audio Library
20:23:09.4 4/9/2012: Creating Surfaces Misc and Dialogs
20:23:10.1 4/9/2012: Creating Surfaces Volume
20:23:10.1 4/9/2012: Creating Surfaces Arrows
20:23:10.1 4/9/2012: Creating Surfaces GameEXlogo Text
20:23:10.1 4/9/2012: Creating Surfaces Toolbar
20:23:10.2 4/9/2012: Creating Surfaces Toolbar Controls
20:23:10.2 4/9/2012: Creating Surfaces Backgrounds
20:23:10.2 4/9/2012: Creating Surfaces GameEx Logo
20:23:10.2 4/9/2012: Creating Surface Unselected
20:23:10.2 4/9/2012: Creating Surfaces Home & Exit
20:23:10.2 4/9/2012: Creating Surfaces Snaps
20:23:10.2 4/9/2012: Creating Surfaces Menu and List Bars
20:23:10.4 4/9/2012: Creating Fonts
20:23:10.4 4/9/2012: Creating Game Font
20:23:10.7 4/9/2012: Creating Game Font Faded
20:23:10.9 4/9/2012: Creating Title Font
20:23:10.9 4/9/2012: Restoring Title Font From Cache
20:23:11.2 4/9/2012: Creating Menu Font
20:23:11.4 4/9/2012: Creating Font Black
20:23:11.5 4/9/2012: Creating Font Black Small
20:23:11.7 4/9/2012: Fonts Created Succesfully
20:23:11.7 4/9/2012: 1MB Video Memory Used
20:23:35.2 4/9/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
20:23:35.2 4/9/2012: Creating DirectSound Device
20:23:35.2 4/9/2012: Trying: Primary Sound Driver
20:23:35.3 4/9/2012: Loading Sound Files
20:23:35.3 4/9/2012: DirectSound Device Created Successfully
20:23:35.3 4/9/2012: Initialising DirectInput for Gamepad support
20:23:35.5 4/9/2012: Using Device Logitech Dual Action
20:23:35.6 4/9/2012: Loading Start Page
20:23:35.7 4/9/2012: Initializing MCE Remote
20:23:35.7 4/9/2012: Playing intro sound file
20:23:35.8 4/9/2012: Initialization OK! Starting GameEx!
20:23:35.8 4/9/2012: Testing Main Loop Once: Processing Frame
20:23:36.7 4/9/2012: Testing Main Loop Once: Main Loop ran successfully
20:23:53.8 4/9/2012: Validating: Emulator_1: Snap Path: C:\Assets\Nintendo NES\Snaps
20:23:53.8 4/9/2012: Validating: Emulator_1: Control Panel Path: C:\Assets\Nintendo NES\Controls
20:23:53.8 4/9/2012: Validating: Emulator_1: Database: [Console] Nintendo NES
20:23:53.8 4/9/2012: Validating: Emulator_1: Title Snap Path: C:\Assets\Nintendo NES\Titles
20:23:53.8 4/9/2012: Validating: Emulator_1: Box Art Path: C:\Assets\Nintendo NES\Boxes
20:23:53.8 4/9/2012: Validating: Emulator_1: Cart Art Path: C:\Assets\Nintendo NES\Cartridges
20:23:53.8 4/9/2012: Validating: Emulator_1: Manual Path: C:\Assets\Nintendo NES\Manuals
20:23:53.8 4/9/2012: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo NES\Snaps
20:23:53.8 4/9/2012: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo NES\Controls
20:23:53.8 4/9/2012: Validating: Emulator_2: Database: [Console] Nintendo NES
20:23:53.8 4/9/2012: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo NES\Titles
20:23:53.8 4/9/2012: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo NES\Boxes
20:23:53.8 4/9/2012: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo NES\Cartridges
20:23:53.8 4/9/2012: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo NES\Manuals
20:23:53.8 4/9/2012: Validating: Emulator_3: Snap Path: C:\Assets\Nintendo SNES\Snaps
20:23:53.8 4/9/2012: Validating: Emulator_3: Control Panel Path: C:\Assets\Nintendo SNES\Controls
20:23:53.8 4/9/2012: Validating: Emulator_3: Database: [Console] Nintendo SNES
20:23:53.8 4/9/2012: Validating: Emulator_3: Title Snap Path: C:\Assets\Nintendo SNES\Titles
20:23:53.8 4/9/2012: Validating: Emulator_3: Box Art Path: C:\Assets\Nintendo SNES\Boxes
20:23:53.9 4/9/2012: Validating: Emulator_3: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
20:23:53.9 4/9/2012: Validating: Emulator_3: Manual Path: C:\Assets\Nintendo SNES\Manuals
20:23:53.9 4/9/2012: Validating: Emulator_4: Snap Path: C:\Assets\Nintendo SNES\Snaps
20:23:53.9 4/9/2012: Validating: Emulator_4: Control Panel Path: C:\Assets\Nintendo SNES\Controls
20:23:53.9 4/9/2012: Validating: Emulator_4: Database: [Console] Nintendo SNES
20:23:53.9 4/9/2012: Validating: Emulator_4: Title Snap Path: C:\Assets\Nintendo SNES\Titles
20:23:53.9 4/9/2012: Validating: Emulator_4: Box Art Path: C:\Assets\Nintendo SNES\Boxes
20:23:53.9 4/9/2012: Validating: Emulator_4: Cart Art Path: C:\Assets\Nintendo SNES\Cartridges
20:23:53.9 4/9/2012: Validating: Emulator_4: Manual Path: C:\Assets\Nintendo SNES\Manuals
20:23:54.3 4/9/2012: Restoring Emulator from Cache: 4
20:23:54.5 4/9/2012: Restoring Emulator Database From Cache: 4
20:25:16.6 4/9/2012: EmUDBCache Diff: 11/28/2011 11:25:20 AM - 11/28/2011 11:25:09 AM
20:25:16.6 4/9/2012: Not Restoring Emulator from Cache: 1
20:25:16.7 4/9/2012: EmUDBCache Diff: 11/28/2011 11:25:20 AM - 11/28/2011 11:25:09 AM
20:25:16.7 4/9/2012: Not Restoring Emulator from Cache: 2
20:25:16.7 4/9/2012: Restoring Emulator from Cache: 3
20:25:16.9 4/9/2012: Restoring Emulator Database From Cache: 3
20:25:33.1 4/9/2012: Creating instance of global keyboard hook
Any help appreciated. Thank you.
Hi jmk, and welcome to the forums!
A couple of questions to assist us in troubleshooting your issue. When you say that games are running fine outside of GameEx, are you running them from the command line or from within the emulator? The other piece of info that would be hugely beneficial would be to take a look at your GameEx config for one or all of the emulators that are giving you difficulties. This information can be found in your GameEx installation directory under ... GameEx\CONFIG\GameEx.ini (this will contain all GameEx settings) or in the interest of brevity you can also export settings for any individual emulator. This can be accomplished from within the setup wizard. Go to the Emulator Selection screen and highlight the emulator you'd like to export settings for, then click the export button (it has an arrow pointing to the right on it) and save the resulting file.
Once we have a better understanding of your emulator settings, we will likely be able to better assist you.
Hi Nullpointer! Thank you for the welcome. :)
I'm not sure what the problem was, but I uninstalled/reinstalled Gameex, set up the emulators again and no longer have any issues.
I think the problem was that somehow I had corrupted the emulator setups.
i noticed one interesting thing. When trying to run the emulators during the first try, it just went to nothing.
When I reinstalled, each time I first started an emulator, Comodo Internet Security was asking if it was okay to run runitgame. That didn't happen the first try.
All is well now.
Thank you for assisting.
GREAT emulator/front-end!
Jo
