Now that the upgrade has helped the list problem with numbering, I created a map file for my playstation games. It worked perfectly.. the first time. The very next time I used GamEx the same problem returned. The games are not in the order of my map file. i.e. I place re-loaded directly under loaded in my map file. The list still puts it alphabetically under r. If I change a name of a game, that registers. The order simply won't stick to my map file.
Edit: after trying a few things, it seems the order is being placed alphabetically by the "good" name side of the list. If I make the last entry:
Zero Divide (USA)|AAA Zero Divide
it will show up first on the list, even though it should still be last.
I see. At least I can stop pulling my hair out. I thought the MAP file would override the settings.
