I am new, but old in Gameex follower. I truly appreciate the posts by all of you who have a great deal more knowledge than I do working with emulators and Gameex. I am attempting to setup SSF in Gameex and I have followed the suggestions by Frequency in a prior post in setting up the config for SSF, but I am still getting a black screen and no game loading. I have attached my ini file for review. I am running Windows XP 32 bit with a AMD Hammer Dual Core chip at 2.0 ghz. Any help that you can point in my direction would be appreciated.
SSF.INI
When using the [VIRTUALDRIVE] in the command-line then there is no need to use the launch before and after using daemon tools. There may be confliction there. So please try that first.
I removed the Launch before and after, but I still get the black screen from SSF in Gameex and outside of it. I read on the SSF website that Socket A chips are not compatible with SSF because they need SSE? I have downloaded Direct X 9.0 and that loaded successfully, but I still cannot get SSF to open up past the black screen. Any suggestions?
Some additional information: I can run SSF outside of Gameex, but get the black screen in Gameex. Outside of Gameex, I have to manually mount the images with Daemon and then open then close the CD drive to make it go. The window display is small and I need to increase the size of the window, but I think that is not important since I am trying to get it to run in Gameex.
That worked perfectly. Thank you. Can you help with Demul to work with Naomi? I can't figure out how to configure it to even make it work outside of Gameex much less in it. Any tips to help with that would be much appreciated.
It's best to start a new topic as this issue was resolved. It makes it easier for other users to track as well. Also state issues you are having with Demul so we know what info is needed to assist.
