Hello all sorry for my english...
I search solution for launch directly SF4 (taito type X) on gameex panel.
In the setting config (gameex set up wizard) for launch SF4 what the command line for run Game.bat file and whats Emulator selected? PC Microsoft??
Thanx for your Help.
Ozy
I'm not running this system as of yet, but I do run some games in the form of batch files (and shortcuts (.lnk) for that matter). It's my understanding that these games will be run directly from batch files, no? If that's the case, the following should work fairly well:
Your emulator path doesn't really matter (so long as one is present). Your emulator command isn't going to reference an executable, so the emulator path can be anything you like. GameEx isn't going to use it anyway. Set it to the same directory as your ROM path if that's what makes sense to you.
Set your ROM directory to the directory which contains your Game.bats.
Your emulator command will be "[ROMPATH]\[ROMFILE]". As far as GameEx goes that should do it. These instructions can pertain to any games in GameEx which run via batch file. Beyond that, there is probably some additional configuration to be done outside of GameEx for these games, which I have zero experience with (I bet someone here has though). Having said that, if your Game.bats work outside of GameEx the above instruvtions should get you going within GameEx.
Good Luck! :D
You must have missed this in your "search"...
