I have an mkv blu-ray rip that plays perfectly in WMP, but is choppy and without sound in the internal player. I'm using the Shark Codec pack. Any body have any ideas as to why this would happen?
also, quick question about launching an external player, would I be able to launch more than one program from the external player command line. Example would be launching MPC-HC and Joy2Key... Would I just separate the calls with a semi colon?
I'm not sure about the sound (might be fixed by changing shark settings) but I know playing HD content in GameEx requires quite a lot more processing power than it does in Windows media player. Something like an atom or pentium won't cut it unfortunatly. You would need some kind of wrapper to launch two programs using the external player feature so its not easily done. Sorry, I realise that is not too helpful.
