I have flat menus for each console (seperate gameex's running)
my question is this....
how do i get a FAVOURITES button to apear on the front menu
eg: it curently has folder entrance into emulator games list with EXIT
I would like, GAMES LIST, FAVOURITES an EXIT all on the first page
I have tried all dfferent varieties of setup but can't seem to get it working..
any idea's please?
any idea's please?
Hi, not 100% what your asking, sounds like your doing some weird stuff with GameEx there! Can you post a screenshot?
The favorites item should show on the start page if its enabled and you have either at least 1 emulator or mame setup. Is it not?
Are you using a custom language? I do, and I had forgotten to fill in the "favorites" field. If it's blank, nothing will show.
Emph
yeah checked that -
what is the idiots guide to adding favourites - what MUS be enabled, etc.. or it to appear in the menu (eg: 2D/3D Menus, etc..)
Thanks.
basically i want to run two seperate versions of gameex.
i have this working now but what do i need to add FAVOURITES to the menu
what needs to be enabled, added, etc???
I have played with the settings but Favourites does not appear on the menu.
Does the START MENU have to be the first page, etc???
Thanks.
Thanks.
Hi, as it said it "should" show on the start page as long as you have either at least 1 emu or mame setup. If it's not showing up in those cases it must be a bug, and as I said please post a screenshot for me to help..
Cheers.
Tom
what would you like screenshot of?  the editor pages or the actual gameex?
if so how would i get the gameex shot?
might want to post your config for him (.txt file) and do a printscreen of gameEx running (then paste in paint or something and save as .jpg).
