Hi!
I'm new to GameEx, but have been using different frontends for many years now. I'd like to switch to GameEx, but I'm having some problems starting the program.
Here's the error message I got:
Testing Main Loop Once: Processing Frame
ERRORS DETECTED: EXITING
at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
at GameEx.GameEx.mainform.DisplayFrame()
Can anyone here help me out?
Hi!
Ill try and help. Can you post the entire log?
22:04:51.5 25-01-2006: GameEx: Version 5.45: Starting Log
22:04:51.5 25-01-2006: Operating System Platform: Win32NT
22:04:51.5 25-01-2006: Operating System Name: Windows XP
22:04:51.5 25-01-2006: Operating System Version: 5.1.2600
22:04:51.5 25-01-2006: Checking for versions of .net Framework installed
22:04:51.5 25-01-2006: .net Framework 1.1 Installed
22:04:51.5 25-01-2006: Checking Registration
22:04:51.5 25-01-2006: Running Randomize()
22:04:51.5 25-01-2006: Initialising Video/MNG DLL's
22:04:51.6 25-01-2006: Running Misc startup tasks
22:04:51.6 25-01-2006: Setting Menu types
22:04:51.6 25-01-2006: Opening Configuration File
22:04:51.6 25-01-2006: Getting Configuration Values
22:04:51.6 25-01-2006: Using Theme: Default - GameEx
22:04:51.6 25-01-2006: Checking for alternate Image Directory for Theme: Default - GameEx
22:04:51.6 25-01-2006: Text/Language: English
22:04:51.6 25-01-2006: Applying Language/Text
22:04:51.7 25-01-2006: Creating Scancodes.txt (List of DirectInput scan codes)
22:04:51.7 25-01-2006: Snap Delay set to: 1
22:04:51.7 25-01-2006: Is Media Center running?
22:04:51.7 25-01-2006: Check Media Center Exit/Start Mode
22:04:51.7 25-01-2006: Media Center Mode 2
22:04:51.7 25-01-2006: Checking for applications to Launch On Startup
22:04:51.7 25-01-2006: Get other settings
22:04:51.7 25-01-2006: Using 2D Animations
22:04:51.7 25-01-2006: Set: Find emulator artwork on best match basis
22:04:51.7 25-01-2006: Launching HideOS.exe
22:04:52.8 25-01-2006: Hiding Taskbar
22:04:52.8 25-01-2006: Start work for Form
22:04:52.8 25-01-2006: Getting Original Screen Size
22:04:52.8 25-01-2006: Loading ICON
22:04:52.8 25-01-2006: Initializing Component
22:04:52.9 25-01-2006: Initialising Bass Audio Library
22:04:53.1 25-01-2006: Loading default loading screen
22:04:53.2 25-01-2006: Using General Font: HandelGothic BT
22:04:53.2 25-01-2006: Using Title Font: HandelGothic BT
22:04:53.2 25-01-2006: Initialising DirectDraw
22:04:53.2 25-01-2006: Creating DirectDraw Device
22:04:53.5 25-01-2006: Setting Resolution to 800x600 32 bit color
22:04:53.8 25-01-2006: Creating DirectDraw Surfaces
22:04:53.8 25-01-2006: Creating Primary Surface - Full Screen Mode
22:04:53.9 25-01-2006: Creating Back Buffer
22:04:53.9 25-01-2006: Loading graphic surfaces
22:04:53.9 25-01-2006: Creating Surfaces Misc and Dialogs
22:04:54.1 25-01-2006: Creating Surface Volume
22:04:54.1 25-01-2006: Creating Surfaces Arrows
22:04:54.1 25-01-2006: Creating Surfaces GameEXlogo Text
22:04:54.1 25-01-2006: Creating Surfaces Toolbar
22:04:54.1 25-01-2006: Creating Surfaces Backgrounds
22:04:55.0 25-01-2006: Creating Surfaces Toolbar Controls
22:04:55.0 25-01-2006: Creating Surfaces GameEx Logo
22:04:55.0 25-01-2006: Creating Surfaces Home & Exit
22:04:55.1 25-01-2006: Creating Surfaces Snaps
22:04:55.1 25-01-2006: Creating Surfaces Menu and List Bars
22:04:55.4 25-01-2006: Creating Fonts
22:04:55.4 25-01-2006: Creating Menu Font
22:04:56.6 25-01-2006: Creating Game Font
22:04:57.1 25-01-2006: Creating Game Font Standard Size
22:04:57.5 25-01-2006: Creating Font Black
22:04:57.6 25-01-2006: Creating Font Black Small
22:04:57.7 25-01-2006: Creating Game Font Faded
22:04:58.0 25-01-2006: Creating Title Font
22:04:58.8 25-01-2006: Creating Control Panel Font
22:04:59.2 25-01-2006: Fonts Created Succesfully
22:05:24.2 25-01-2006: Initialising Windows Media Player Component
22:05:24.5 25-01-2006: MAME Path is: g:\mame32
22:05:24.5 25-01-2006: Cannot Find MAME Path: MAME Disabled
22:05:24.5 25-01-2006: Loading Controls.ini map file
22:05:24.5 25-01-2006: Loading Custom Emulators
22:05:24.9 25-01-2006: MAME CMD options: -triplebuffer -nowindow -joy
22:05:24.9 25-01-2006: Attempting to load game list
22:05:25.0 25-01-2006: Loading last used Game List
22:05:25.0 25-01-2006: Setting Music Volume
22:05:25.0 25-01-2006: Creating DirectSound Device
22:05:25.1 25-01-2006: Trying: Primary Sound Driver
22:05:25.1 25-01-2006: Loading Sound Files
22:05:25.2 25-01-2006: DirectSound Device Created Successfully
22:05:25.2 25-01-2006: Initialising DirectInput for Gamepad support
22:05:25.4 25-01-2006: Unable to create a joystick device
22:05:25.4 25-01-2006: Playing intro sound file
22:05:25.4 25-01-2006: Initializing MCE Remote
22:05:25.4 25-01-2006: Initialization OK! Starting GameEx!
22:05:25.4 25-01-2006: Testing Main Loop Once: Processing Frame
22:05:25.8 25-01-2006: ERRORS DETECTED: EXITING
22:05:26.2 25-01-2006: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
22:05:26.2 25-01-2006: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
22:05:26.2 25-01-2006: at GameEx.GameEx.mainform.DisplayFrame()
I use Windows XP
Hardware:laptop
Intel Pentium 4 CPU 2.66GHz, 480 MB of RAM
I have a pretty crappy graphics card on my laptop: SiS M6r50_651_650_740
video memory type: DDR SDRAM, video memory size: 32,0 Mbytes, video memory clock 133 MHz
I tried to switch to 16-bit color, but that didn't help!
Thank you for your help!
I use Windows XP
Hardware:laptop
Sorry, I think you might be out of luck. I think your video card may not be up to the job.
2 things to try though:
Turn off advanced graphics.
Use a lower resolution.
Okay I'll try!
Btw I used an older version of GameEx a year ago, and that one ran just fine. But I guess the program has advanced since then, and my laptop is too old, as you said.
Anyway, thanks for your help!
Okay I'll try!
Yes, its come a long way. The laptop sounds OK, just the video card.
You could check for newer drivers, and also check nothing else is conflicting.
Also try running dxdiag.exe
