Krakerman Posted February 8, 2012 Share Posted February 8, 2012 Ok guys so I setup another version of MAME within gameex but when I hit the ESC key to exit back to GameEX it crashes with the following:22:37:42.3 2/7/2012: Exiting Game22:37:42.3 2/7/2012: Closing Process22:37:43.7 2/7/2012: Writing Stats22:37:43.7 2/7/2012: Plugin: Game Exit22:37:43.7 2/7/2012: Plugin: Process Commands22:37:43.8 2/7/2012: Initialising Audio22:37:43.9 2/7/2012: Relaunching HideOS22:37:44.1 2/7/2012: Restoring Window22:37:44.1 2/7/2012: Reinitializing Graphics System22:37:44.2 2/7/2012: Mouse Input is disabled22:37:45.6 2/7/2012: Shutting down RawInput Hook22:37:45.6 2/7/2012: Writing MAME stats22:37:45.7 2/7/2012: Plugin: Game Exit22:37:45.7 2/7/2012: Plugin: Process Commands22:37:45.7 2/7/2012: Restoring Window22:37:45.7 2/7/2012: Reinitializing Graphics System22:37:45.9 2/7/2012: Mouse Input is disabled22:37:47.0 2/7/2012: Returning to GameEx22:37:47.4 2/7/2012: 21 Consecutive Exceptions Occured22:37:47.4 2/7/2012: Index was outside the bounds of the array.22:37:47.4 2/7/2012: at ag.t(Boolean A_0)22:37:47.4 2/7/2012: at ag.ad()22:37:47.4 2/7/2012: Trying reinitialising the display after sleeping for 4 seconds22:37:47.4 2/7/2012: Exception count will be dropped to 1522:37:51.6 2/7/2012: Mouse Input is disabled22:37:52.8 2/7/2012: --**--22:37:52.8 2/7/2012: 21 Consecutive Exceptions Occured: Exiting22:37:52.8 2/7/2012: Closing database connection22:37:52.8 2/7/2012: First Exception:22:37:52.8 2/7/2012: Index was outside the bounds of the array.22:37:52.8 2/7/2012: at ag.t(Boolean A_0)22:37:52.8 2/7/2012: at ag.ad()22:37:52.8 2/7/2012: Last Exception:22:37:52.8 2/7/2012: Index was outside the bounds of the array.22:37:52.9 2/7/2012: at ag.t(Boolean A_0)22:37:52.9 2/7/2012: at ag.ad() Link to comment Share on other sites More sharing options...
Adultery Posted February 8, 2012 Share Posted February 8, 2012 I researched this some and it could be a problem with either your MAP file (if you're using one), the emulator crashing instead of closing, or anti-virus software getting in the way. Do any of these three things apply to this emulator for you? To be honest I'm leaning towards a MAP file, but AV software would be a good place to start. And of course, you should put your full LOG since I can't see if this crash occured in thefirst time you ran a game, the command line it used, your path settings, etc. Link to comment Share on other sites More sharing options...
Krakerman Posted February 8, 2012 Author Share Posted February 8, 2012 The rest of that error log didn't seem to pertain to any issue that I saw. I will look over my mameemumap and everything is in order hmmmmmm. Will look over it again tomorrow night Link to comment Share on other sites More sharing options...
Krakerman Posted February 9, 2012 Author Share Posted February 9, 2012 Fixed it!Tracked it down to being the background image was not properly set. Link to comment Share on other sites More sharing options...
