I have 2 control panels I use on my cab and have created cpwizard configs for both. Is there any way to quickly have cpw switch from one to the other without going into the app?
Check out "Layout Maps" in Edit->Options. You can have CPW display certain layouts based on the control type.
CPWizard also supports "multi-layouts". To create a multi-layout you name them with a subscript.
Eg. MyLayout (0).xml, MyLayout (1).xml and so on.
When viewing your CP you can move left or right to rotate through them.
