This is a just a new idea I may have for my HTPC but is there any way to run different (multiple) copies of GameEx on one machine?
Depending on licensing terms and that but I have ried it oly to find it errors out..
eg: c:\gameex\gameex
and c:\gameexamiga\gameex
this is a new idea im working on but i can't seem to get it working???
You should be able to run multiple installs of GameEx on the same PC, but not at the same. If one of your installs is not working, its likely just your configuration.
ok. thats my thoughts but when i try and run the config program i get this error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: The specified module could not be found.
at MySetting.MySetting.MySettingControl..ctor()
at MySetting.MySetting.frmSubPage.LoadPage()
at MySetting.MySetting.frmSubPage.frmSubPage_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
GameExConfig
Assembly Version: 1.0.1.0
Win32 Version: 1.0.1.0
CodeBase: file:///C:/GameEx-Amiga/GameExConfig.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.3052.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Interop.WMPLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/GameEx-Amiga/Interop.WMPLib.DLL
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Microsoft.DirectX.DirectInput
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///c:/windows/assembly/gac/microsoft.directx.directinput/1.0.2902.0__31bf3856ad364e35/microsoft.directx.directinput.dll
Interop.DvdCore
CodeBase: file:///C:/GameEx-Amiga/Interop.DvdCore.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
any idea's?
nevermind - its now sorted it appears there was a problem with a line for one of my emulators was incorrect -
thanks or your help!
