[RESOLVED] Problem starting Gamex: need alt+tab for work fine
Hello, everybody, i'm new posting in this forum, but i reading from one year ago, and now i need help with this situation:;
My problem is GameEx start on fullscreen sometimes the screen go black, the lower left corner show a white field "GameEx |||| 0/60" or "GameEx |||| 64/60" , then i hear the intro video,but i must press alt+tab and navigate to gameex for show the main menu, then, sometimes, work fine an sometimes there is not joystick and must restart.
If Gameex start windowed there is no problem.
In previous version this work ok.
Gameex 12.54 licensed
SO: Windows XPsp3 full shelled using malauncher for start joytokey an then gameex together and connected to internet.
Bye
PD:Sorry for my ugly english, is not my native language
Please post your GameEx log. It may provide a good indication of what is happening here. Ideally you should reproduce the error you’ve described here, and then post your GameEx log here before starting GameEx again.
No need to apologize about language barrier, we’re a pretty diverse crowd around here. I always have a lot of admiration and respect for the multi-lingual folks we have in the community. :D
Thanks, and Welcome to the Forums!
Ok :) , this is my initial windows pre Alt+Tab after hear startup video
http://img687.images...lackscreenr.jpg
and this is my log
22:46:46.0 25/01/2012: Opening Configuration File
22:46:46.4 25/01/2012: GameEx: Version 12.54: Starting Log
22:46:46.4 25/01/2012: Operating System Platform: Win32NT
22:46:46.4 25/01/2012: Operating System Name: Windows XP
22:46:46.4 25/01/2012: Operating System Version: 5.1.2600
22:46:46.4 25/01/2012: AMD Athlon™ XP 3000+, 1024MB
22:46:46.5 25/01/2012: 2,17Ghz
22:46:46.5 25/01/2012: Running Randomize()
22:46:46.8 25/01/2012: Loading PlugIns
22:46:46.9 25/01/2012: Checking for applications to Launch On Startup
22:46:46.9 25/01/2012: Running Misc startup tasks
22:46:46.9 25/01/2012: Setting Menu types
22:46:46.9 25/01/2012: Getting Configuration Values
22:46:47.1 25/01/2012: Using Theme: Acidbrain Vision
22:46:47.1 25/01/2012: Checking for alternate Image Directory for Theme: Acidbrain Vision
22:46:47.1 25/01/2012: Launching HideOS.exe
22:46:47.1 25/01/2012: Initialising Video/MNG DLL's
22:46:47.1 25/01/2012: GameEx will check for media insertion (may affect performance)
22:46:47.1 25/01/2012: Hiding Taskbar
22:46:47.2 25/01/2012: Is Media Center running?
22:46:47.2 25/01/2012: Checking/Creating LCD Registry values
22:46:47.5 25/01/2012: Check Media Center Exit/Start Mode
22:46:47.5 25/01/2012: Media Center Mode 2
22:46:47.6 25/01/2012: Video previews on. Warning: Only recommended on modern systems
22:46:47.7 25/01/2012: Custom Keyboard Input enabled: Getting custom codes
22:46:47.7 25/01/2012: Advanced Custom Keyboard Input enabled: Getting custom codes
22:46:47.7 25/01/2012: Custom Game Device Input enabled: Getting custom codes
22:46:47.8 25/01/2012: Snap Delay set to: 3
22:46:47.8 25/01/2012: Get other settings
22:46:47.8 25/01/2012: Desktop set to Hide ICONS and set Background to Black
22:46:47.8 25/01/2012: Using DirectInput for keyboard input
22:46:47.8 25/01/2012: Start work for Form
22:46:47.8 25/01/2012: Getting Original Screen Size
22:46:47.8 25/01/2012: Opening Database Connection
22:46:50.4 25/01/2012: Initializing Component
22:46:50.7 25/01/2012: MAME Path is: D:\Emulators\mame
22:46:50.8 25/01/2012: Model 2 Path Path is: D:\Emulators\Model2
22:46:50.8 25/01/2012: Model 2 EXE file is: emulator.exe
22:46:50.8 25/01/2012: Model 2 emulator with command line support detected
22:46:50.8 25/01/2012: Use Model 2 on. emulator.exe will launch Sega Model 2 games
22:46:50.8 25/01/2012: ZiNc Path is: D:\Emulators\zinc
22:46:50.8 25/01/2012: ZiNc EXE file is: ZiNc.exe
22:46:50.8 25/01/2012: Use ZiNc on. ZiNc.exe will launch PSX games
22:46:50.8 25/01/2012: MAME EXE file is: mamep.exe
22:46:50.9 25/01/2012: ROM Path is: D:\Emulators\mame\roms
22:46:50.9 25/01/2012: Catver.ini is located at: D:\GameEx\DATA\catver.ini
22:46:50.9 25/01/2012: controls.ini is located at: D:\GameEx\data\controls.ini
22:46:50.9 25/01/2012: History.dat is located at: D:\GameEx\DATA\history.dat
22:46:50.9 25/01/2012: nplayers.ini is located at: D:\GameEx\DATA\nplayers.ini
22:46:50.9 25/01/2012: command.dat is located at: D:\GameEx\DATA\command.dat
22:46:50.9 25/01/2012: MAMEinfo.dat is located at: D:\GameEx\DATA\mameinfo.dat
22:46:51.0 25/01/2012: Loading Controls.ini map file
22:46:51.0 25/01/2012: Snap Path is: D:\Emulators\mame\snap
22:46:51.0 25/01/2012: Background Snap Path is: D:\Emulators\mame\snap
22:46:51.0 25/01/2012: AVI Snap Path is: D:\Emulators\mame\vidsnap
22:46:51.0 25/01/2012: Flyer Path is: D:\Emulators\mame\flyers
22:46:51.0 25/01/2012: Cabinet Path is: D:\Emulators\mame\Cabinet
22:46:51.0 25/01/2012: Cabinet 3D Path is: D:\Emulators\mame\cabinets3d
22:46:51.0 25/01/2012: Title Path is: D:\Emulators\mame\titles
22:46:51.0 25/01/2012: PCB Path is: D:\Emulators\mame\pcb
22:46:51.1 25/01/2012: Artwork Preview Path is: D:\Emulators\mame\artwork
22:46:51.1 25/01/2012: Panel Path: Not Found
22:46:51.1 25/01/2012: Manual Path is: D:\Emulators\mame\manuals
22:46:51.1 25/01/2012: Icon Path is: D:\Emulators\mame\icons
22:46:51.1 25/01/2012: Marquee Path is: D:\Emulators\mame\Marquee
22:46:51.1 25/01/2012: Applying Language/Text
22:46:51.1 25/01/2012: Text/Language: Spanish
22:46:51.3 25/01/2012: Loading Custom Emulators
22:46:51.3 25/01/2012: Loading Emulator 1: [Arcade] Arcade (CPS-3)
22:46:51.4 25/01/2012: Loading Emulator 2: [Arcade] Arcade (FB Alpha)
22:46:51.4 25/01/2012: Loading Emulator 3: [Arcade] Arcade (Mjolnir)
22:46:51.4 25/01/2012: Loading Emulator 4: [Arcade] Arcade (Raine)
22:46:51.5 25/01/2012: Loading Emulator 5: [Arcade] Arcade (WinKawaks)
22:46:51.5 25/01/2012: Loading Emulator 6: [Arcade] Arcade (ZiNc)
22:46:51.5 25/01/2012: Loading Emulator 7: [Arcade] Model 2 (Model2)
22:46:51.5 25/01/2012: Loading Emulator 8: [Arcade] Sammy Atomiswave (DEmul)
22:46:51.5 25/01/2012: Loading Emulator 9: [Arcade] Sega Naomi (DEmul)
22:46:51.5 25/01/2012: Loading Emulator 10: [Console] Nientiendo N64
22:46:51.5 25/01/2012: Loading Emulator 11: [Console] Nintendo NES (Nestopia)
22:46:51.5 25/01/2012: Loading Emulator 12: [Console] Sega Dreamcast (nullDC)
22:46:51.5 25/01/2012: Loading Emulator 13: [Pinball] Visual Pinball
22:46:51.6 25/01/2012: Loading Emulator 14: [Pinball] Future Pinball
22:46:51.6 25/01/2012: Loading Emulator 15: Raiden II
22:46:51.6 25/01/2012: Loading Emulator 16: Thunder
22:46:51.7 25/01/2012: Using 2D Animations
22:46:51.7 25/01/2012: Retrieving resolution setting
22:46:51.7 25/01/2012: Using General Font: Trebuchet MS
22:46:51.7 25/01/2012: Using Title Font: Trebuchet MS
22:46:51.7 25/01/2012: Initialising Direct3D
22:46:52.1 25/01/2012: Setting Resolution to 1024x768 32 bit color
22:46:52.1 25/01/2012: Creating Surfaces
22:46:54.5 25/01/2012: Creating Primary Surface - Full Screen Mode
22:46:54.5 25/01/2012: Creating Back Buffer
22:46:55.2 25/01/2012: Version 2 Theme being used. Loading.
22:46:55.2 25/01/2012: Loading Button Data
22:46:55.2 25/01/2012: Loading Font Data
22:46:55.2 25/01/2012: Loading Layout Data
22:46:55.6 25/01/2012: Loading Taskbar Data
22:46:55.6 25/01/2012: Loading graphic Surfaces
22:46:55.7 25/01/2012: Display is running at: 1024x768 32bit color, 60hz
22:46:55.7 25/01/2012: Adapter: NVIDIA GeForce 6600 GT
22:46:55.7 25/01/2012: Max texture size: 4096x4096
22:46:55.7 25/01/2012: Available texture memory: 169MB
22:46:55.7 25/01/2012: Initialising Bass Audio Library
22:46:57.7 25/01/2012: Creating Surfaces Misc and Dialogs
22:46:58.7 25/01/2012: Creating Surfaces Volume
22:46:58.8 25/01/2012: Creating Surfaces Arrows
22:46:59.9 25/01/2012: Creating Surfaces GameEXlogo Text
22:46:59.9 25/01/2012: Creating Surfaces Toolbar
22:47:01.4 25/01/2012: Creating Surfaces Toolbar Controls
22:47:02.0 25/01/2012: Creating Surfaces Backgrounds
22:47:02.0 25/01/2012: Creating Surfaces GameEx Logo
22:47:02.2 25/01/2012: Creating Surface Unselected
22:47:02.4 25/01/2012: Creating Surfaces Home & Exit
22:47:02.8 25/01/2012: Creating Surfaces Snaps
22:47:02.8 25/01/2012: Creating Surfaces Menu and List Bars
22:47:05.5 25/01/2012: Creating Fonts
22:47:05.5 25/01/2012: Creating Game Font
22:47:08.2 25/01/2012: Creating Game Font Faded
22:47:08.4 25/01/2012: Creating Title Font
22:47:08.5 25/01/2012: Restoring Title Font From Cache
22:47:09.3 25/01/2012: Creating Menu Font
22:47:09.6 25/01/2012: Creating Font Black
22:47:09.9 25/01/2012: Creating Font Black Small
22:47:10.1 25/01/2012: Fonts Created Succesfully
22:47:10.1 25/01/2012: 169MB Video Memory Used
22:47:13.4 25/01/2012: Attempting to load game list
22:47:20.9 25/01/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
22:47:21.0 25/01/2012: Creating DirectSound Device
22:47:21.0 25/01/2012: Trying: Controlador primario de sonido
22:47:21.0 25/01/2012: Loading Sound Files
22:47:22.0 25/01/2012: DirectSound Device Created Successfully
22:47:22.0 25/01/2012: Initialising DirectInput for Gamepad support
22:47:22.2 25/01/2012: Using Device LPT1: LPT-switch Joystick 1
22:47:22.2 25/01/2012: Using Device LPT1: LPT-switch Joystick 2
22:47:22.7 25/01/2012: Initialising DirectInput for Keyboard support
22:47:23.0 25/01/2012: Loading Start Page
22:47:23.5 25/01/2012: Initializing MCE Remote
22:47:23.5 25/01/2012: Playing intro sound file
22:47:23.5 25/01/2012: Initialization OK! Starting GameEx!
22:47:23.5 25/01/2012: Testing Main Loop Once: Processing Frame
22:47:29.0 25/01/2012: Testing Main Loop Once: Main Loop ran successfully
22:47:47.4 25/01/2012: Exiting GameEx!
22:47:47.4 25/01/2012: Disposing all videos
22:47:47.4 25/01/2012: Deleting temporary Karaoke videos
22:47:47.4 25/01/2012: Disposing Image List
22:47:47.4 25/01/2012: Disposing Fonts
22:47:47.4 25/01/2012: Disposing Surfaces
22:47:47.4 25/01/2012: Saving Settings
22:47:47.6 25/01/2012: Shutting down Bass
22:47:47.6 25/01/2012: Closing HideOS.exe
22:47:49.9 25/01/2012: Disposing Plugins
22:47:49.9 25/01/2012: Closing database connection
22:47:49.9 25/01/2012: Checking for applications to Launch On Exit
22:47:49.9 25/01/2012: Bye
thanks!
Something must be stealing focus from GameEx... You're not using an nlited or tinyxp build of XP are you?
Hehehe, still editing and already have response, very nice :)
Is a Xp Pofessional with many service cutted off by control panel.
Yes, look like lost focus issue. May be daemon tools lite, installed after shelling...mmm, ok i make a test without this tool.
Thanks!
Yeah, thanks Adultery, the problem was lost focus, unistall D-tool resolve the problem, but i need it, i make the test again installing the last version.
bye!
Confirmed, the problem is gone.
The solution:
1) Unshell the S.O.
2) Uninstall D-Tool and restart
3) Install last version of D-Tool Lite and restart
4) shell the system and restart
and problem is gone!
Thanks!
Bye
PD: Please mark as resolved
Glad you got it working. :)
