Hey everyone.....I've been playing around with GameEx for awhile and have set up all of my emulators and everything is working great for the most part. Great program and definitely worth the donation fee!!
I am sure these questions have been asked and are very basic but I couldn't find anything in the search so bare with me if they are repeats.
First question is, upon opening up GameEx, I get the Nintendo 64 back from the grave screen......is this default? Can I disable that screen and if so, where do I do that??
Second question is, I have some dvds I have ripped and converted to .avi, .mkv, etc. I put them in my windows My Videos directory. However, under my Multimedia>Videos option in GameEx, I have numerous Video directories. I can see my videos in a couple of the Videos directory but others don't have any. It's almost as if GameEx found every video directory on my computer and puts them in that list. How do I get it so it only shows the one directory with my music dvds I ripped and converted?
I hope these questions make sense. If you need any other info, please let me know. The FAQ was very good reading and has helped me out with a lot of other questions.
Thanks everyone!!
1. GameEx has themes and your currently selected theme shows that intro logo. You can change your theme via the setup wizard. You can also disable that startup animation (logo) under Enable/Disable features in the setup wizard.
You set the video path under multimedia settings in the setup wizard. Delete the folders in the text box for videos paths with your keyboard then select browse and select the folder you want.
Awesome....Thanks Tom!! That worked out perfectly.
Great piece of software you have here......I can't believe how customizable it is...a little overwhelming for a newbie like myself but definitely great to have all of these options. I wouldn't have it any other way!!
Peja
