Hello :)
I have got execute a game with gameex using windows xp. I have followed the website’s guide: Setting up Pc game Tutorial for Gameex.
I can start the game with gameex, but it doesn’t start in fullscreen. The following game starts in fullscreen if I press ALT GR + ENTER.
My current command line is: ""[ROMPATH]\[ROMFILE]""
How can I modify it for get the fullscreen?
Thanks!
I also report my current configuration:
[Emulator_14]
STARTPAGENAME=PC Games
TITLETEXT=PC Games
StartPageLogo=PC Games
ROMFilter=*.lnk
RomPath=C:\EMU\HNK beta 6
RomsInFolders=True
SnapPath=C:\EMU\HNK beta 6\Videos
TitlePath=
BoxPath=
CartPath=
ManualPath=C:\EMU\HNK beta 6\Manuals PDF
ControlPanelPath=
InstructionsPath=
TVAdPath=
MusicPath=
ImageNotFound=
WorkingPath=C:\EMU\HNK beta 6
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
MapFile=
AlsoLaunch=
Command=""[ROMPATH]\[ROMFILE]""
LaunchBefore=
LaunchAfter=
ConfigFile=[Mapping Off] Exit (Process Close)
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
Database=
UseDbName=
GamesIn7Zips=False
MergeSets=
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
CustomArtName4=
CustomArtPath4=
CustomArtName5=
CustomArtPath5=
GameExtenderCustomArtPath=
GameExtenderConstants=
System=Microsoft Windows
Category=PC
Emulator=Windows
Version=
Rating=
DownloadUrl=
RequiredFiles=
Website=
Info=
OLDatZip=
if the game can't be sent to start in full screen mode then you can use the 'Wait Before Keys' and 'Keys To Send' options in the 'Advanced Emulator Setup' page to send Alt+Enter
In the 'Wait Before Keys' box enter a time in milliseconds e.g. 3000 is 3 seconds
In the 'Keys To Send' box type:
%{ENTER}
No when you start the game GameEx will wait 3 seconds then send Alt+Enter making the game fullscreen
Stu
%{ENTER}
I have tried, but it doesn’t work. The game starts to window and not in fullscreen. Maybe because %{ENTER} command is equivalent to Alt+Enter. Instead the game starts in fullscreen with ALT GR + ENTER keys.
The command ALT GR + ENTER, what is it referring to?
The game has realized with the M.U.G.E.N.
This is the link where download the game: http://www.hokutoproject.it/forum/viewtopic.php?f=29&t=180
That is correct! That would be why it's not working. So just modify that sendkeys to accommodate what's required. By GR do you mean the letters G & R?
no he mean the alt key on the right hand side of the keyboard.. on some keyboards this is labeled as 'Alt Gr'
I'm not sure what the command is for this though
Stu
Stu
Ahhhh! Gotcha! In that case I don't see that key under the Send Keys Class and google didn't turn up anything for me either other than it's not supported so there will have to be a workaround. Either programatically or by using a 3rd party app. Is there no way of changing the key within this particular game?
GameEx doesn't use .NET's built in SendKeys API; it's actually a port of a C++ class I did.
If you check out GameEx\CONFIG\EMULATORS\SendKeys.htm you can see it has the ability to send custom Virtual Keycodes.
The left and right alt keys are called VK_LMENU and VK_RMENU. Their values are 0xA4 (164) and 0xA5 (165) respectively.
You can send VK_RMENU using {VKEY 165}. Unfortuantely there is no way to hold down a non-modifier key and only VK_MENU ('%') is supported as a modifier.
The only way around it would be to write a script in AutoHotkey to press the key combo. Under it's KeyList it says
LAlt - the left Alt key
RAlt - Note: If your keyboard layout has AltGr instead of RAlt, you can probably use it as a hotkey prefix via <^>! as described here. In addition, "LControl & RAlt::" would make AltGr itself into a hotkey.
So that might be worth a try.
