This seems to have fixed the problem.
First I downloaded the latest version and installed. Then I reset the shark codecs. I didn't understand what to do with the file you gave me at first, so next I started up GameEx. It seemed to run fine, even the video snaps were playing smoothly, but then I closed and restarted GameEx. This time when I scrolled to Recently Played the screen went black and then reappeared working again. Same thing happened when I scrolled to Favorites. Then I closed and restarted GameEx a third time. This time the screen went black and back again on Recently Played, then jammed up when I tried to scroll to Favorites. I'm just telling you all this in case you want to know.
I then figured out what the file was that you gave me so I replaced the GameEx.exe with the one I had and ran GameEx again. This time it runs fine. There is sometimes a slight hesitation when I first scroll over Recently Played, Favorites, etc, but not too bad. The background images are loading.
What is special about the .exe you gave me? Should I use this version after future upgrades? Thanks a lot.
