[RESOLVED] Troubles with Emulator Background & Forground
Myghalloween
Hi all,
Also in the creation of my future theme for GameEx, codenamed "eXion" I discovered a new problem with Theme Editor. I'll try to be as clear as possible.
First here are some screenshots :
This is the start menu, it is composed of a transparent background and a foreground component (StarBak.png and StartBak_Foreground.png in MEDIA folder of theme)
post-8828-0-27510200-1325953927_thumb.jp
When I go to the Console menu, everything is ok.
post-8828-0-88384600-1325954004_thumb.jp
When I go to the menu NES console, it retains the StartBak_Foreground.png Background on the NES
post-8828-0-43847900-1325953993_thumb.jp
Also attached background NES only in case
post-8828-0-68486300-1325953957_thumb.jp
So I create a foreground for the menu for the NES component is larger to cover the game list (Theme_Background_Nintendo NES_Foreground.png in MEDIA folder of theme).
And the problem is that the component appears superimposed transparent layers with transparent pane StartBak_Foreground.png
post-8828-0-11726100-1325953965_thumb.jp
So I tried with a non-transparent foreground, only the logo and everything works, the StartBak_Foreground.png no longer appears.
post-8828-0-44238200-1325953980_thumb.jp
Yet it works with MAME menu.
The transition between the menu and menu selection of games is ok (Bak_Foreground.png in MEDIA folder)
post-8828-0-02387000-1325953949_thumb.jppost-8828-0-36514100-1325953941_thumb.jp
My only solution for the NES menu is to make a transparent background incorporating pane, but I find it a pity for the further development of my theme.
Like that :
post-8828-0-20037000-1325953973_thumb.jp
A solution?
Thank you for read (and understood)
myg
Link to comment
Share on other sites
