Hello - I am trying to run PC Jukebox and I want to set it up as an external application. I can run the program fine with out gameex but when I try to run it from with in it I get a black screen and then right back to gameex. I have tried all options in the config menu...any ideas?
thanks
Added later:
I am not sure if this matters but there are spaces in the .exe - anyone have luck running an exe with spaces?
thanks
Added later:
I just set up my PC version of MK4, and the exe is Motral Kombat 4.exe, and it didn't work. Same issue, got the black screen, then right back to Gameex. I renamed the file mk4.exe, and now it works fine. So, does seem the external app launching has some issues with executables with spaces. I tried putting quotation marks around the file also as windows does, but didn't help.
Thankfully the program still runs with the exe renamed, so not a big deal.
I tried to rename it and it would not go...I do know some things can have a space in the exe because the config for "Future Pinball.exe" under emuators has a space in it but it does not run unless I rename it. If anyone has had luck with an exe with a space please let me know.
thanks for the reply....
I found that Future Pinball.exe will not work on mine unless renamed. Anyone know if some updates caused the spaces not to work?
thanks...
