hi
can anyone help me out... installing an upto date gameex on my 2k box to checkout
whats new.... as dont want to put it on my cab just yet
anyway installed gameex ... installed mameuifx... added roms... and setup
now i can run games from mameuifx and i can run the last game run.bat
and my games work. but when in gameex and try to run a game it just drops back to
gameex tryed all sorts... and yes its bin a long time sin i last setup gameex lol
so please anyone... help!!!
my log
10:03:02.4 29/12/2011: Opening Configuration File
10:03:02.5 29/12/2011: GameEx: Version 12.44: Starting Log
10:03:02.5 29/12/2011: Operating System Platform: Win32NT
10:03:02.5 29/12/2011: Operating System Name: Windows 2000
10:03:02.5 29/12/2011: Operating System Version: 5.0.2195
10:03:02.5 29/12/2011: Intel® Pentium® 4 CPU 3.00GHz, 1015MB
10:03:02.5 29/12/2011: 3Ghz - 2 Cores or CPU's
10:03:02.5 29/12/2011: Running Randomize()
10:03:02.5 29/12/2011: Loading PlugIns
10:03:02.5 29/12/2011: Checking for applications to Launch On Startup
10:03:02.5 29/12/2011: Running Misc startup tasks
10:03:02.5 29/12/2011: Setting Menu types
10:03:02.5 29/12/2011: Getting Configuration Values
10:03:02.5 29/12/2011: Using Theme: Default - COM v4
10:03:02.5 29/12/2011: Checking for alternate Image Directory for Theme: Default - COM v4
10:03:02.5 29/12/2011: Launching HideOS.exe
10:03:02.5 29/12/2011: Initialising Video/MNG DLL's
10:03:02.5 29/12/2011: GameEx will check for media insertion (may affect performance)
10:03:02.5 29/12/2011: Hiding Taskbar
10:03:02.5 29/12/2011: Using Cabinet Friendly Control System
10:03:02.5 29/12/2011: Is Media Center running?
10:03:02.5 29/12/2011: Checking/Creating LCD Registry values
10:03:02.6 29/12/2011: Check Media Center Exit/Start Mode
10:03:02.6 29/12/2011: Media Center Mode 2
10:03:02.6 29/12/2011: Video previews on. Warning: Only recommended on modern systems
10:03:02.6 29/12/2011: Custom Game Device Input enabled: Getting custom codes
10:03:02.6 29/12/2011: Snap Delay set to: 2
10:03:02.6 29/12/2011: Get other settings
10:03:02.6 29/12/2011: Desktop set to Hide ICONS and set Background to Black
10:03:02.6 29/12/2011: Set: Find emulator artwork on best match basis
10:03:02.6 29/12/2011: Start work for Form
10:03:02.6 29/12/2011: Getting Original Screen Size
10:03:02.6 29/12/2011: Opening Database Connection
10:03:02.7 29/12/2011: Initializing Component
10:03:02.7 29/12/2011: MAME Path is: C:\emul\mame
10:03:02.7 29/12/2011: MAME EXE file is: mameuifx32.exe
10:03:02.7 29/12/2011: ROM Path is: D:\rom
10:03:02.7 29/12/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
10:03:02.7 29/12/2011: controls.ini is located at: C:\GameEx\DATA\controls.ini
10:03:02.7 29/12/2011: History.dat is located at: C:\GameEx\DATA\history.dat
10:03:02.7 29/12/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
10:03:02.7 29/12/2011: command.dat is located at: C:\GameEx\DATA\command.dat
10:03:02.7 29/12/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
10:03:02.7 29/12/2011: Loading Controls.ini map file
10:03:02.7 29/12/2011: Snap Path is: C:\arcade\mame pics
10:03:02.7 29/12/2011: AVI Snap Path is: C:\arcade\mame game videos
10:03:02.7 29/12/2011: Flyer Path is: C:\emul\mame\flyers
10:03:02.7 29/12/2011: Cabinet Path is: C:\arcade\mame cab
10:03:02.7 29/12/2011: Cabinet 3D Path: Not Found
10:03:02.7 29/12/2011: Title Path is: C:\emul\mame\titles
10:03:02.7 29/12/2011: PCB Path: Not Found
10:03:02.7 29/12/2011: Artwork Preview Path: Not Found
10:03:02.7 29/12/2011: Panel Path is: C:\arcade\mame cpanels
10:03:02.7 29/12/2011: Manual Path: Not Found
10:03:02.7 29/12/2011: Icon Path is: C:\arcade\mame icons
10:03:02.7 29/12/2011: Marquee Path is: C:\arcade\mame marquees
10:03:02.8 29/12/2011: Applying Language/Text
10:03:02.8 29/12/2011: Text/Language: English
10:03:02.9 29/12/2011: Loading Custom Emulators
10:03:02.9 29/12/2011: Using 3D Alpha Blended Animations.
10:03:02.9 29/12/2011: Retrieving resolution setting
10:03:02.9 29/12/2011: Using General Font: Trebuchet MS
10:03:02.9 29/12/2011: Using Title Font: Trebuchet MS
10:03:02.9 29/12/2011: GameEx will try to reduce CPU usage
10:03:03.0 29/12/2011: Initialising Direct3D
10:03:03.1 29/12/2011: Mouse Input is disabled
10:03:03.1 29/12/2011: Applying GameEx is Loading Image
10:03:03.2 29/12/2011: Setting Resolution to 1024x768 32 bit color
10:03:03.2 29/12/2011: Creating Surfaces
10:03:03.3 29/12/2011: Creating Primary Surface - Full Screen Mode
10:03:03.3 29/12/2011: Creating Back Buffer
10:03:03.3 29/12/2011: Version 2 Theme being used. Loading.
10:03:03.3 29/12/2011: Loading Button Data
10:03:03.3 29/12/2011: Loading Font Data
10:03:03.3 29/12/2011: Loading Layout Data
10:03:03.4 29/12/2011: Loading Taskbar Data
10:03:03.4 29/12/2011: Loading graphic Surfaces
10:03:03.4 29/12/2011: Display is running at: 1024x768 16bit color, 60hz
10:03:03.4 29/12/2011: Adapter: Intel® 82945G Express Chipset Family
10:03:03.4 29/12/2011: Max texture size: 2048x2048
10:03:03.4 29/12/2011: Available texture memory: 40MB
10:03:03.4 29/12/2011: Initialising Bass Audio Library
10:03:03.5 29/12/2011: Creating Surfaces Misc and Dialogs
10:03:03.6 29/12/2011: Creating Surfaces Volume
10:03:03.6 29/12/2011: Creating Surfaces Arrows
10:03:03.6 29/12/2011: Creating Surfaces GameEXlogo Text
10:03:03.6 29/12/2011: Creating Surfaces Toolbar
10:03:03.7 29/12/2011: Creating Surfaces Toolbar Controls
10:03:03.7 29/12/2011: Creating Surfaces Backgrounds
10:03:03.7 29/12/2011: Creating Surfaces GameEx Logo
10:03:03.8 29/12/2011: Creating Surface Unselected
10:03:03.8 29/12/2011: Creating Surfaces Snaps
10:03:03.8 29/12/2011: Creating Surfaces Menu and List Bars
10:03:04.0 29/12/2011: Creating Fonts
10:03:04.0 29/12/2011: Creating Game Font
10:03:04.1 29/12/2011: Creating Game Font Faded
10:03:04.2 29/12/2011: Creating Title Font
10:03:04.7 29/12/2011: Creating Font Black
10:03:04.8 29/12/2011: Creating Font Black Small
10:03:05.0 29/12/2011: Fonts Created Succesfully
10:03:05.0 29/12/2011: 1MB Video Memory Used
10:03:05.5 29/12/2011: Playing Startup Video on thread
10:03:05.5 29/12/2011: Attempting to load game list
10:03:05.8 29/12/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
10:03:05.8 29/12/2011: Creating DirectSound Device
10:03:05.8 29/12/2011: Trying: Primary Sound Driver
10:03:05.8 29/12/2011: Loading Sound Files
10:03:05.8 29/12/2011: DirectSound Device Created Successfully
10:03:05.8 29/12/2011: Initialising DirectInput for Gamepad support
10:03:06.0 29/12/2011: Using Device Xin-Mo Dual Arcade
10:03:06.1 29/12/2011: Loading Start Page
10:03:06.2 29/12/2011: Initializing MCE Remote
10:03:14.1 29/12/2011: Playing intro sound file
10:03:14.1 29/12/2011: Initialization OK! Starting GameEx!
10:03:14.1 29/12/2011: Testing Main Loop Once: Processing Frame
10:03:14.7 29/12/2011: Testing Main Loop Once: Main Loop ran successfully
10:03:26.0 29/12/2011: Restoring Cached ICONS from File
10:03:44.7 29/12/2011: Setting Up RawInput Hook
10:03:44.7 29/12/2011: Launching RawInputHook.exe
10:03:45.9 29/12/2011: Running: cmd.exe /c C: C:\emul\mame\mameuifx32.exe gngc -rompath D:\rom -nowindow -joy -skip_gameinfo
10:03:46.0 29/12/2011: Shutting down display
10:03:48.8 29/12/2011: Shutting down RawInput Hook
10:03:48.8 29/12/2011: Writing MAME stats
10:03:48.9 29/12/2011: Plugin: Game Exit
10:03:48.9 29/12/2011: Plugin: Process Commands
10:03:48.9 29/12/2011: Restoring Window
10:03:48.9 29/12/2011: Reinitializing Graphics System
10:03:48.9 29/12/2011: Mouse Input is disabled
10:03:50.8 29/12/2011: Returning to GameEx
10:04:00.4 29/12/2011: Exiting GameEx!
10:04:00.4 29/12/2011: Saving Settings
10:04:01.4 29/12/2011: Disposing Plugins
10:04:01.4 29/12/2011: Closing database connection
10:04:01.4 29/12/2011: Checking for applications to Launch On Exit
thanks loads carl.
