Oh no Tom! This one is causing major problems. I'll grab a video shot to show you.
Is this a newly introduced issue?
Can you post theme.ini please.
I only just stated installing the emulators, so I don't know if this is a new issue. Please let me know if you see anything else askew or redundant.
THEME.INI
[General]
Version=4
Width=1280
Height=800
XRESOLUTION=1280
YRESOLUTION=800
StartupVideo=False
ArcadeMode=False
DisplayBackgroundImage=Snap
GradientTitleFont=True
AniBak=False
AlphaBlendVideos=True
AnimatedSelector=False
ShowButtons=True
CustomEmulatorLayouts=True
CustomControlPanel=False
DisplayEmulatorMenus=True
RotatePlus90=False
DialogTextWhite=True
DisplayTitleText=True
Font=DejaVu Sans Condensed
TextColor=-1
FontStyle=1
FontSize=6
MainFontSize=20
TitleFontStyle=0
TitleTextColor=ffffff
TitleFont=Comfortaa
TitleFontSize=84
LowerCaseTitleFont=True
OutlineFonts=False
OutlineColor=-16777216
EnableMediaControls=True
HideToolBar=0
MakeToolbarTextWhite=True
CustomModuleLayouts=True
AntiAliasFonts=True
ShowDateTime=True
ShowListNumbers=True
ShowSelectionText=True
RightJustifyTitleText=True
AlphaChannel=True
EnablePopUpDescriptions=False
ForeGroundTopMost=True
StaticStartPageList=True
DontZoomStartPageLogos=True
[TaskBar]
MCEButtonOver=10,400,206,46
MCEButtonDown=10,400,206,46
BackButtonOver=10,700,206,46
BackButtonDown=10,700,206,46
HelpButtonOver=60,700,206,46
HelpButtonDown=60,700,206,46
MediaControl=54,732,200,48
MediaControlStop=54,732,200,48
TopBarLeft=0,400,200,46
TopBarMiddle=0,600,200,46
Window=1279,45,32,32
[Buttons]
ArrowDown=1279,799,1,1
ArrowDownPressed=1279,799,1,1
ArrowUp=1279,799,1,1
ArrowUpPressed=1279,799,1,1
HomeNoFocus=80,300,41,37
HomeFocus=80,300,41,37
ExitNoFocus=60,600,41,37
ExitFocus=60,600,41,37
ExitSelect=60,600,41,37
[Layout]
Title=0,672,1279,99
SelectLine1=1279,0,259,47
SelectLine2=1279,0,259,47
Date=1078,45,103,47
Time=930,45,106,47
Weather=840,46,33,33
List=10,144,320,611
Image=0,0,1279,799
Image2=900,480,400,300
ListNum=1279,0,182,47
Menu=2,6,200,47
Scroller=390,772,906,30
Description=100,100,100,100
[Weather]
Enabled=False
WeatherConditionIcon=False
START_MODULE.INI
[Layout]
Title=0,672,1260,174
SelectLine1=1279,0,235,43
SelectLine2=1279,0,235,43
Date=1084,46,93,43
Time=938,46,96,43
List=20,280,320,240
Image=0,0,1279,799
Image2=350,626,248,126
ListNum=1279,0,165,43
Menu=2,6,200,43
Can you try setting the resolution in the setup wizard to the same as the theme and see if the problem persists.
Thanks.
The resolution was already set for 1280x800.
Can you post the log with the attached after launching a game please.
14:16:12.7 5/23/2012: Opening Configuration File
14:16:12.7 5/23/2012: GameEx: Version 12.61: Starting Log
14:16:12.7 5/23/2012: Operating System Platform: Win32NT
14:16:12.7 5/23/2012: Operating System Name: Windows 7
14:16:12.7 5/23/2012: Operating System Version: 6.1.7601
14:16:12.8 5/23/2012: Aero running
14:16:12.8 5/23/2012: Initializing Vista/Windows 7 volume control
14:16:12.8 5/23/2012: Intel(R) Pentium(R) D CPU 3.20GHz, 2558MB
14:16:12.8 5/23/2012: 3.19Ghz - 2 Cores or CPU's
14:16:12.8 5/23/2012: Running Randomize()
14:16:12.8 5/23/2012: Loading PlugIns
14:16:12.8 5/23/2012: Checking for applications to Launch On Startup
14:16:12.8 5/23/2012: Running Misc startup tasks
14:16:12.8 5/23/2012: Setting Menu types
14:16:12.8 5/23/2012: Getting Configuration Values
14:16:12.8 5/23/2012: Using Theme: Beta
14:16:12.8 5/23/2012: Checking for alternate Image Directory for Theme: Beta
14:16:12.9 5/23/2012: Launching HideOS.exe
14:16:12.9 5/23/2012: Initialising Video/MNG DLL's
14:16:12.9 5/23/2012: GameEx will check for media insertion (may affect performance)
14:16:12.9 5/23/2012: Hiding Taskbar
14:16:12.9 5/23/2012: Is Media Center running?
14:16:12.9 5/23/2012: Checking/Creating LCD Registry values
14:16:12.9 5/23/2012: Check Media Center Exit/Start Mode
14:16:12.9 5/23/2012: Media Center Mode 2
14:16:13.0 5/23/2012: Video previews on. Warning: Only recommended on modern systems
14:16:13.0 5/23/2012: Snap Delay set to: 7
14:16:13.0 5/23/2012: Get other settings
14:16:13.0 5/23/2012: Desktop set to Hide ICONS and set Background to Black
14:16:13.0 5/23/2012: Set: Find emulator artwork on best match basis
14:16:13.0 5/23/2012: Start work for Form
14:16:13.0 5/23/2012: Getting Original Screen Size
14:16:13.0 5/23/2012: Opening Database Connection
14:16:13.1 5/23/2012: Initializing Component
14:16:13.2 5/23/2012: MAME Path is: L:\[LITHIUM]\[ARCADE]\MAME\mame
14:16:13.2 5/23/2012: Cannot Find MAME Path: MAME Disabled
14:16:13.2 5/23/2012: Loading Controls.ini map file
14:16:13.3 5/23/2012: Applying Language/Text
14:16:13.3 5/23/2012: Text/Language: Custom
14:16:13.3 5/23/2012: Loading Custom Emulators
14:16:13.3 5/23/2012: Loading Emulator 1: [Console] Nintendo SNES (Snes9x)
14:16:13.3 5/23/2012: Loading Emulator 2: [Console] Nintendo NES (VirtuaNES)
14:16:13.4 5/23/2012: Loading Emulator 3: [Console] Sega Genesis (Fusion)
14:16:13.4 5/23/2012: Loading Emulator 4: [Console] Sega Master System (Fusion)
14:16:13.4 5/23/2012: Using Version 3 Themes Animations
14:16:13.4 5/23/2012: Retrieving resolution setting
14:16:13.4 5/23/2012: Using General Font: DejaVu Sans Condensed
14:16:13.4 5/23/2012: Using Title Font: Comfortaa
14:16:13.4 5/23/2012: GameEx will try to reduce CPU usage
14:16:13.4 5/23/2012: Initialising Direct3D
14:16:13.6 5/23/2012: Applying GameEx is Loading Image
14:16:13.7 5/23/2012: Setting Resolution to 1280x800 32 bit color
14:16:13.7 5/23/2012: Creating Surfaces
14:16:14.2 5/23/2012: Creating Primary Surface - Full Screen Mode
14:16:14.2 5/23/2012: Creating Back Buffer
14:16:14.2 5/23/2012: Version 2 Theme being used. Loading.
14:16:14.2 5/23/2012: Loading Button Data
14:16:14.2 5/23/2012: Loading Font Data
14:16:14.2 5/23/2012: Loading Layout Data
14:16:14.2 5/23/2012: Loading Taskbar Data
14:16:14.2 5/23/2012: Loading graphic Surfaces
14:16:14.2 5/23/2012: Display is running at: 1280x800 32bit color, 60hz
14:16:14.2 5/23/2012: Adapter: NVIDIA GeForce 210
14:16:14.2 5/23/2012: Max texture size: 8192x8192
14:16:14.2 5/23/2012: Available texture memory: 1478MB
14:16:14.2 5/23/2012: Initialising Bass Audio Library
14:16:14.3 5/23/2012: Creating Surfaces Misc and Dialogs
14:16:14.4 5/23/2012: Creating Surfaces Volume
14:16:14.4 5/23/2012: Creating Surfaces Arrows
14:16:14.5 5/23/2012: Creating Surfaces GameEXlogo Text
14:16:14.5 5/23/2012: Creating Surfaces Toolbar
14:16:14.5 5/23/2012: Creating Surfaces Toolbar Controls
14:16:14.6 5/23/2012: Creating Surfaces Backgrounds
14:16:14.6 5/23/2012: Creating Surfaces GameEx Logo
14:16:14.6 5/23/2012: Creating Surface Unselected
14:16:14.6 5/23/2012: Creating Surfaces Snaps
14:16:14.6 5/23/2012: Creating Surfaces Menu and List Bars
14:16:14.7 5/23/2012: Creating Fonts
14:16:14.7 5/23/2012: Creating Game Font
14:16:14.7 5/23/2012: Create Game Font
14:16:14.7 5/23/2012: Font Size: Bold
14:16:14.7 5/23/2012: WidthScreen: 1280
14:16:14.7 5/23/2012: ThemeWidth: 1280
14:16:14.9 5/23/2012: Creating Game Font Faded
14:16:15.1 5/23/2012: Creating Title Font
14:16:15.1 5/23/2012: Restoring Title Font From Cache
14:16:15.5 5/23/2012: Creating Font Black
14:16:15.5 5/23/2012: Creating Font Black Small
14:16:15.6 5/23/2012: Fonts Created Succesfully
14:16:15.6 5/23/2012: 4MB Video Memory Used
14:16:15.7 5/23/2012: Loading News Feed: http://www.gameex.net/gameexnews.xml
14:16:27.3 5/23/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
14:16:27.3 5/23/2012: Sound Disabled
14:16:27.3 5/23/2012: Initialising DirectInput for Gamepad support
14:16:27.4 5/23/2012: Unable to create a joystick device
14:16:27.4 5/23/2012: Loading Start Page
14:16:27.5 5/23/2012: Initializing MCE Remote
14:16:27.5 5/23/2012: Initialization OK! Starting GameEx!
14:16:27.5 5/23/2012: Testing Main Loop Once: Processing Frame
14:16:27.9 5/23/2012: Testing Main Loop Once: Main Loop ran successfully
14:16:35.8 5/23/2012: Validating: Emulator_1: Custom Background: theme_background_nintendo snes.png
14:16:35.8 5/23/2012: Validating: Emulator_1: Snap Path: L:\ARCADE\SNES\system\snaps
14:16:35.8 5/23/2012: Validating: Emulator_1: Database: [Console] Nintendo SNES
14:16:35.8 5/23/2012: Validating: Emulator_2: Custom Background: theme_background_nintendo nes.png
14:16:35.8 5/23/2012: Validating: Emulator_2: Snap Path: L:\ARCADE\NES\snaps
14:16:35.8 5/23/2012: Validating: Emulator_2: Control Panel Path: \Nintendo NES\Controls
14:16:35.8 5/23/2012: Warning: Emulator_2: Control Panel Path Does not exist
14:16:35.8 5/23/2012: Validating: Emulator_2: Database: [Console] Nintendo NES
14:16:35.8 5/23/2012: Validating: Emulator_4: Snap Path: \Sega Master System\Snaps
14:16:35.8 5/23/2012: Warning: Emulator_4: Snap Path Does not exist
14:16:35.8 5/23/2012: Validating: Emulator_4: Control Panel Path: \Sega Master System\Controls
14:16:35.8 5/23/2012: Warning: Emulator_4: Control Panel Path Does not exist
14:16:35.8 5/23/2012: Validating: Emulator_4: Database: [Console] Sega Master System
14:16:35.8 5/23/2012: Validating: Emulator_4: Title Snap Path: \Sega Master System\Titles
14:16:35.8 5/23/2012: Warning: Emulator_4: Title Snap Path Does not exist
14:16:35.8 5/23/2012: Validating: Emulator_4: Box Art Path: \Sega Master System\Boxes
14:16:35.8 5/23/2012: Warning: Emulator_4: Box Art Path Does not exist
14:16:35.8 5/23/2012: Validating: Emulator_4: Cart Art Path: \Sega Master System\Cartridges
14:16:35.8 5/23/2012: Warning: Emulator_4: Cart Art Path Does not exist
14:16:35.8 5/23/2012: Validating: Emulator_4: Manual Path: \Sega Master System\Manuals
14:16:35.8 5/23/2012: Warning: Emulator_4: Manual Path Does not exist
14:16:36.2 5/23/2012: Restoring Emulator from Cache: 1
14:16:36.3 5/23/2012: Restoring Emulator Database From Cache: 1
14:16:38.3 5/23/2012: Restoring Emulator from Cache: 2
14:16:38.4 5/23/2012: Restoring Emulator Database From Cache: 2
14:16:40.8 5/23/2012: Creating instance of global keyboard hook
14:16:40.8 5/23/2012: Running: cmd.exe /c L: snes9x.exe -fullscreen "L:\ARCADE\SNES\system\roms\Super Mario World (U) [!].zip"
14:16:41.0 5/23/2012: Shutting down display
14:16:46.5 5/23/2012: Exiting Game
14:16:46.5 5/23/2012: Closing Process
14:16:49.2 5/23/2012: Writing Stats
14:16:49.2 5/23/2012: Plugin: Game Exit
14:16:49.2 5/23/2012: Plugin: Process Commands
14:16:49.2 5/23/2012: Refreshing Keyboard
14:16:49.3 5/23/2012: Initialising Audio
14:16:49.3 5/23/2012: Relaunching HideOS
14:16:49.6 5/23/2012: Restoring Window
14:16:49.7 5/23/2012: Reinitializing Graphics System
14:16:50.2 5/23/2012: Create Game Font
14:16:50.2 5/23/2012: Font Size: Bold
14:16:50.2 5/23/2012: WidthScreen: 1280
14:16:50.2 5/23/2012: ThemeWidth: 1280
14:16:51.8 5/23/2012: Reloading Game Info Page
14:16:51.9 5/23/2012: Returning to GameEx
14:17:08.5 5/23/2012: Exiting GameEx!
14:17:08.5 5/23/2012: Disposing all videos
14:17:08.5 5/23/2012: Deleting temporary Karaoke videos
14:17:08.5 5/23/2012: Disposing Image List
14:17:08.5 5/23/2012: Disposing Fonts
14:17:08.5 5/23/2012: Disposing Surfaces
14:17:08.5 5/23/2012: Saving Settings
14:17:08.5 5/23/2012: Shutting down Bass
14:17:08.7 5/23/2012: Closing HideOS.exe
14:17:09.0 5/23/2012: Disposing Plugins
14:17:09.0 5/23/2012: Closing database connection
14:17:09.0 5/23/2012: Checking for applications to Launch On Exit
14:17:09.0 5/23/2012: Media Center was not open when starting GameEx, so not launching
14:17:09.0 5/23/2012: Bye
Just wondering why is says:
when it's a V4 theme
I think we've got a winner Tom!! Looks much better! Thanks for the quick fixes!!
Uhmmm... maybe the cause was this: after loading and quitting that snes game, GameEx set the resolution to 1280x1280 instead of the initial 1280x800?
That was just some debugging text I added Alpha. I believe I have fixed the issue. Also some other potential issues with themes too.
Lookin' good Chazz!
  • 1 month later...
>Bump<
Hi Chazz!
I just wanted to check in with you to see how Confluence:GEX is coming along. I can barely wait to see a completed version of this theme! I’m hoping that you won’t let it languish as it’s way too awesome to never see the light of a full release! (You've also clearly put a ton of work and craftsmanship into this thing).
OTOH sometimes you need to take a break from projects like this in order to return with new enthusiasm. And naturally sometimes these projects take a back seat to real life.
So this intended as encouragement more than anything. There’s a lot of community excitement behind this project. Thanks for all the work you’ve put into it!
Perhaps if you’ll entertain the notion I might be allowed to make a brief comparison. Two exceedingly brilliant men, both a bit reclusive, but for different reasons.
Henry David Thoreau vanished from the public eye so that he might, “live deliberately, to front only the essential facts of life, and see if (he) could not learn what it had to teach, and not, when (he) came to die, discover that (he) had not lived.”
Much later wealthy industrialist Howard Hughes also chose to withdraw from the public eye. This was so he could sit naked in a personal film screening room watching Ice Station Zebra 150 times in a row, all the while choosing to relieve himself in empty milk jars for fear of using the proper facilities.
Chazz in your case I very much hope it’s the former and not the later. :D
Nah, seriously though, I hope you don’t mind the razzing. :P I’m just running out of ways to express the collective anticipation for this sweet, sweet theme. Any news on a release date?
I’ve also noticed that your image hosting has gone tits up. I hope that all is well on your end, and that this isn’t an indication of the sort of public withdrawal I mention above. We miss you buddy! Feel free to let one of us know if you’re in search of alternate hosting options!
EDIT: The prodigal son has returned! (and he brought his Spruce Goose with him ;)). Good to see you back Chazz. :D
Really looking forward to this theme... it's going to be the perfect final touch to my new XBMC/GameEx htpc build that I'm currently working on
Stu
