HELP! I'm playing around trying to get my assets in order, and I was switching the view in GameEx Atari 2600 MESS front part, and I kept clicking change view till I got these really larger icons and now the change view command/menu item is gone and I'm stuck in this view and I hate it. Also, in using the EmuMovies downloader to download various assets it seems to want to use for example atari_2600 where as GameEx wants to use Atari 2600. Do I only have to change the .ini file entries in GameEx to point to the EmuMovies downloader system using the _? Thanks, I am willing to RESET my view if that is needed as well. I can't figure out where it is saving this or how to reset it. A key combo to change view would be great, or a reset.
captcpsc
(I am a PROUD new registered GameEx user)
The icon to change the view is a monitor with stars on it if that helps any. :)
