16th January 2006
- GameEx 5.41
  • Lots of improvements to
    GameExtender
  • More stable.
  • GameExtender now rotates
    artwork when available
  • Displays Control Panel when
    available.
  • When GameExtender is disabled
    takes next to no additional resources.
  • GameExtender Viewer should definitely
    work on Second display now.
  • Refresh rate option for
    viewer.
  • Also in this release:
  • Should fix Screensaver for
    some users.
  • Screensaver now allows
    playing videos only
Just download and install the new version. Your settings will stay.
Toonces
Which rocks btw (though I would still recommend backups as always). divemaster127, don't be too worried about keeping up with Tom though, he puts updates out like mad ;-) I usually update every .1 or so unless I run into an issue that is solved by one inbetween (has not happened yet).
just my $.02
